Problem with New Install
Old Aug 12, 2005 | 02:51 PM
  #51
TR-S2K's Avatar
Hi Mike,
I emailed StereoSource@sbcglobal.net about GT-22. The seller does not allow pickup and she would not discount shipping charge. So that the total price will be $199 + 7.75% tax + $32 shipping + $3 Insurance = $249.42
The 4-channel GT-40 specs is below:
Multi-Ch. Power @ 4-ohm (12.6VDC): 4x45W
Multi-Ch. Power @ 2-ohm (12.6VDC): 4x70W
Dual-Mono Power @ 4-ohm(12.6VDC): 2x140W
Dual-Mono Power @ 2-ohm (12.6VDC): 2x175W
Mixed Op. Power @ 4-ohm, 2ohm (12.6VDC): 2x45W, 1x190W
Mixed Op. Power @ 4-ohm, 2ohm (14.4VDC): 2x55W, 1x240W
Frequency Response (-3dB): 10Hz-95kHz
Signal to Noise Ratio (A Weighted): >100dB
Height: 2-1/4" (57mm)
Width: 14-1/8" (358mm)
Depth (w/Mounting Feet): 8-7/8" (225mm)
Note: Dual-Mono Power @ 4-ohm(12.6VDC): 2x140W, which is more than GT-24 (2x120W @ 4-ohm(12.6VDC))
If you split the front 2 channels to 4, the two left channels are connected to front inputs, the two right channels are connected to the rear inputs, then using bridge mode to drive the front left speaker with front output and right front speaker with rear outputs, you have 140Wrms for each front speaker. The only problem is this amp is too big for under seat mounting, it can be installed behind the seat. Since you have sub amp behind driver seat, it may need to move to behind passenger seat and install this GT-40 behind driver seat. Also, it cost a little more at $279 + $30 shipping and insurance.
Old Aug 12, 2005 | 03:04 PM
  #52
TR-S2K's Avatar
Hi Mike,
I am leaving work now. I will take a long drive home via PCH (Pacific Coast Highway) for relieving tress. I will log in later tonight and hope that I will have your PM. I will be on vacation for two weeks starting Aug-20, I would like to resolve this before I leave for vacation, please cooperate.
S2000alldahy
Nov 13, 2013 06:37 AM
Mr Dave
27
May 26, 2009 10:36 AM
scho01
Mar 27, 2006 01:04 PM
jwa4378
Dec 26, 2005 08:32 AM
PJK3
Mar 28, 2003 09:54 AM
