Quick S-Pod Speaker Question
Old Dec 15, 2008 | 03:19 PM
ZachV's Avatar
Default Quick S-Pod Speaker Question
I just got some S-pods and have a 2005 that is supposedly pre-wired for rear speakers, I am going to be running just a regular coaxial 5.25" and was wondering if I need to upgrade my amp and where exactly the 'pre-wire' harness is (I am fairly new to electronics installations) thanks so much.
Old Dec 15, 2008 | 03:23 PM
SheDrivesIt's Avatar
The 2005 is NOT prewired for rear speakers (unless a previous owner wired it for you (unlikely). I would be inclined to run them off the radio's rear channels. If you have amplified door speakers, adding S-pods to the mix will make them WAY too loud and will probably drop your impedance load too low for most amps. What kind of amp are you running?
Old Dec 15, 2008 | 03:43 PM
ZachV's Avatar
On the S-pod website it says 04+ is pre wired for rear speakers (the OEM accessory ones for the seats) so I just assumed mine was as well.
My entire system is stock, and I look to keep it that way.
EDIT- searched for a while and found that indeed the 04-05 do have a prewire, it is in the driver knee panel. However I read that the stock HU is quite underpowered, so can anyone suggest a moderately priced 5.25" coaxial speaker set that will work well with the stock HU? I would really appreciate it, thanks.
Old Dec 17, 2008 | 06:32 AM
asukadc's Avatar
you head unit will support it, but you have to run the wires yourself.
Old Dec 17, 2008 | 10:21 AM
ZachV's Avatar
It is my understanding that the harness taped up under the knee panel, I just have to tap those wires and run them to the roll loops. Would you recommend running them through the center console?
Old Dec 21, 2008 | 05:23 PM
jwa4378's Avatar
Center console would be easiest... just make sure you keep them away from other power wires.
John
suzuka-blue-s2k
Dec 7, 2010 06:50 AM
evolution
Aug 19, 2007 09:10 AM
nureulwihaesuh
May 5, 2004 04:27 AM
hirev
Dec 4, 2003 08:30 PM
GamecockS2K
Jun 9, 2003 06:17 PM
