Remote Start and PKALL help
Old Jan 12, 2009 | 12:19 PM
  #31
Stealth_SUX_'s Avatar
yep ur right its both or none. If you cut the wire and not tap into it u will have the antigrind feature as well as the starter disable. But if you just tap the wire you wont have any of that.
The12volt.com is open to anyone to post, so its as reliable as wiki is, some joe can just post something. For good information go to directed electronics website.
Old Jan 12, 2009 | 01:40 PM
  #32
devilchrist's Avatar
got it. i asked the question on the the12volt forum and they said it's program feature #1-9
"automatic engine disable off" which is default,
I have to turn this feature on and car will not start when armed even with key.
I have to try this when I get home.
Another problem solved!
*EDIT* you know come to think of it.. it's quite scary... few of my friends cars with 791x have that feature of default, with the 556U unit. this is how they give the car's to customer from many installers,
better tell them about this shet.. or it's practically give thier car away to theives.
Old Jan 12, 2009 | 02:01 PM
  #33
i hate 556u. cause u can just break the 556u case open and take the key out and unplug the alarm and start the car lol...
Old Jan 13, 2009 | 05:16 PM
  #34
HankookS2K's Avatar
Originally Posted by NFRS2K83' date='Jan 11 2009, 11:23 PM
in the s2000 there are 2 ignition wires... 2 accessory wires and 1 starter wire...
so are you saying the orange wire is a 2nd accessory?
Old Jan 14, 2009 | 07:30 AM
  #35
Here's what the wiring diagra says.
key ignition module -> orange wire -> relay (starter button triggered) -> black/white wire -> starter
1st ignition connection should be one of the black/yellow (I can't recall if there was 2 black/yellow)
2nd ignition connection should be black/red so radiator fan can run as well as HVAC during remote start ( i just made this connection as well so my car doesn't over heat during remote start)
accessory is white/red
Originally Posted by modifry
blk/red on the output side of the ign sw is for the AC/heat, ABS, and the radiator fan relays. You will need to power this circuit if you expect the fans to run
Then there are 2 blk/yellow and 1 Org. These 3 wires are actually connected together inside the ign sw
Old Jan 14, 2009 | 08:19 AM
  #36
yup i had it this way for my previous cars and never felt safe, now matter how well I hid it.
someone can always break the steering colum trace the antena wire and find it.
bypass kit makes it easier to hide and no antena.
Old Jan 17, 2009 | 06:46 AM
  #37
NFRS2K83's Avatar
damn this thread is still going... lol... whenever i use a U... i cut the end off the key so the car cannot be started... works easier and safer like this... hehe
Old Aug 19, 2010 | 03:06 AM
  #38
nte11igence's Avatar
I'm gonna have to bump this as I have the same problem with my newly installed python 991. The car only remote starts after turning the key to the on position. I have the pkall wired up and everything seems to be fine as I checked my connections.
Funny thing is....the LED on the antenna constantly stays on AND I'm not valet mode. The same goes for the parking lights...they don't flash on and off when i arm/disarm the alarm...they constantly stay on, so the connection is currently disconnected.
any ideas?
Old Jul 27, 2012 | 03:18 PM
  #39
Duyx817's Avatar
up! i have the same problem... please helpppppp.. i have been working on this for months now lmao..
Old Jul 28, 2012 | 03:45 PM
  #40
vspc2nr's Avatar
theres a "secret" 2nd ignition, use your DMM to find it
bb_chris1688
Jan 21, 2014 12:17 PM
Jay walker
Feb 6, 2013 11:39 AM
afwfjustin
Sep 25, 2012 11:32 AM
j0000stin
Apr 28, 2012 11:58 AM
dreamsforgotten
Jul 23, 2008 03:55 PM
