Reverse switch wire location and pic?
Old Sep 13, 2015 | 09:51 AM
ceophlo's Avatar
Default Reverse switch wire location and pic?
Not sure if this has been asked already. I did a quick search and couldn't find anything. I'm a new 2000 s2k ap1 owner. I'm getting back into the swing of things, my last honda (acura) was an integra more than 10 years ago. I'm a noob at electronic stuff but I'm still savy enough that I installed a head unit in the car. Now my next project is a BACK UP camera. You maybe wondering what I will be viewing the backup image on. I hunted down a boss bv7948b. They no longer make them but it has bluetooth, dvd, sd slot, usb, video input, video output, back up cam, and a 3.6 inch screen just small enough for an s2k with the radio door. Now i want to wire my backup camera and I need to find the reverse wire. I'm having a hell of a time finding wire diagrams for my year car and pictures to know exactly what I'm looking for. I know how to splice and solder but i just need to know exactly what wire I need to cut. I'm scared I will cut the wrong wire. Please help.
Old Sep 14, 2015 | 01:43 PM
oth's Avatar
oth
HTH (from the Electrical Troubleshooting Manual):
Old Sep 27, 2015 | 12:03 PM
ceophlo's Avatar
Thanks a lot
Old Apr 19, 2016 | 08:00 AM
thetangstr's Avatar
I understand about the back light part, but what does connect terminal do?
I'm installing a new mirror with both front and rare cam. I'm assuming they will need to be powered separately? Can you someone share the details of the hard wiring part? I'm pretty new to s2k...
Old Dec 4, 2016 | 05:27 PM
ceophlo's Avatar
What mirror are you running?
Also I know this was a long time ago but if you're still trying to do this I can tell you what I did. I did a lot of googling. This post helped me finish. Using the diagram above I was able to locate the reverse wire. You just need to connect the reverse wire to the reverse input on the headunit. Then it needs to be powered. I tapped the power from the reverse light since it only gets power when the car is in reverse. For the front cam that would need constant 12v I'm assuming. You can run a wire under the dash and use a fuse tap on one of the fuses that gives 12v when the ignition is on. Hope that helps.
Old Dec 4, 2016 | 06:55 PM
shrykhar's Avatar
FYI I also have a backup camera, and I tapped the reverse light. The camera needs power so you'll have to tap that location anyway.
geared
Aug 25, 2012 05:49 PM
s20001988
Apr 20, 2012 10:23 PM
siadam
Jul 3, 2010 08:59 AM
r_duff
Jun 24, 2005 02:46 PM
amongmany
Mar 14, 2005 05:07 PM
