S2000-specific Audio/Electronics FAQ v.2.37
to be added to the FAQ:
Garage Door Opening by headlight flashing.
https://www.s2ki.com/forums/index.php?showt...dpost&p=8524986
to be added on the next update:
DIY HU guide for AP2's (on an '06)
https://www.s2ki.com/forums/index.php?showt...dpost&p=8103771
to be added on next update:
S2000.org Hardwiring Radar Detector DIY.
http://www.s2000.org/mods/radar/
(looks like i've about 3 things to add now - so, i'll update this soon. that's usually my benchmark for editing and checking links)
Originally Posted by Snick24,Jun 26 2007, 08:49 PM
Was wondering if anyone could send me the info on how to take off all the panels in order to do an install? I am thinking of adding a new Hu, components in doors, and a sub in the trunk with an amp to run the components and the sub. Does anyone have this set up and how does it sound? Thanks
[QUOTE]
[B]Running wires for your S2000 stereo system?
updated 6/27/07.
i did not have time today to hit every single link in the FAQ and verify them to be good. as always, if you notice dead links -- please post them here and i'll either try to find the updated link, replace the link, or attempt to mark them dead with the hope they may come back.
This might be helpful for FAQs. Might be something on it there already../shrug
Keep in mind that length is a factor here as well. If you're doing a long run (>20 feet), you should use one size larger. It doesn't hurt to use a wire size that's larger than necessary, but it will usually cost more and can be more difficult to install.
Power Wire:
10 gauge: ~35 amperes
Class D (~70% efficiency) - <350 watts
Class A/B (~50% efficiency) - <250 watts
8 gauge: ~55 amperes
Class D (~70% efficiency) - <550 watts
Class A/B (~50% efficiency) - <400 watts
6 gauge: ~87 amperes
Class D (~70% efficiency) - <875 watts
Class A/B (~50% efficiency) - <625 watts
4 gauge: ~140 amperes
Class D (~70% efficiency) - <1400 watts
Class A/B (~50% efficiency) - <1000 watts
2 gauge: ~220 amperes
Class D (~70% efficiency) - <2200 watts
Class A/B (~50% efficiency) - <1500 watts
1/0 gauge: ~350 amperes
Class D (~70% efficiency) - <3500 watts
Class A/B (~50% efficiency) - <2500 watts
Speaker wire: 4 ohms is what most of us will use.
22 gauge: ~2.2 amperes
8 ohms - <36 watts
6 ohms - <27 watts
4 ohms - <18 watts
3 ohms - <13.5 watts
2 ohms - <9 watts
1 ohm - <4.5 watts
20 gauge: ~3.4 amperes
8 ohms - <96 watts
6 ohms - <72 watts
4 ohms - <48 watts
3 ohms - <36 watts
2 ohms - <24 watts
1 ohm - <12 watts
18 gauge: ~5.5 amperes
8 ohms - <240 watts
6 ohms - <180 watts
4 ohms - <120 watts
3 ohms - <90 watts
2 ohms - <60 watts
1 ohm - <30 watts
16 gauge: ~8.7 amperes = Probably shouldn't go any smaller if you're using an amp to push components.
8 ohms - <600 watts
6 ohms - <450 watts
4 ohms - <300 watts
3 ohms - <225 watts
2 ohms - <150 watts
1 ohm - <75 watts
14 gauge: ~13.7 amperes
8 ohms - <1500 watts
6 ohms - <1125 watts
4 ohms - <750 watts
3 ohms - <563 watts
2 ohms - <375 watts
1 ohm - <188 watts
12 gauge: ~21.8 amperes
8 ohms - <3800 watts
6 ohms - <2850 watts
4 ohms - <1900 watts
3 ohms - <1425 watts
2 ohms - <950 watts
1 ohm - <475 watts
10 gauge: ~34.6 amperes
8 ohms - <9600 watts
6 ohms - <7200 watts
4 ohms - <4800 watts
3 ohms - <3600 watts
2 ohms - <2400 watts
1 ohm - <1200 watts
8 ohms - <24000 watts
6 ohms - <18000 watts
4 ohms - <12000 watts
3 ohms - <9000 watts
2 ohms - <6000 watts
1 ohm - <3000 watts
Power Wire:
8 ohms - <36 watts
6 ohms - <27 watts
4 ohms - <18 watts
2 ohms - <9 watts
1 ohm - <4.5 watts
8 ohms - <96 watts
6 ohms - <72 watts
4 ohms - <48 watts
3 ohms - <36 watts
2 ohms - <24 watts
1 ohm - <12 watts
8 ohms - <240 watts
6 ohms - <180 watts
4 ohms - <120 watts
3 ohms - <90 watts
2 ohms - <60 watts
1 ohm - <30 watts
8 ohms - <600 watts
6 ohms - <450 watts
4 ohms - <300 watts
3 ohms - <225 watts
2 ohms - <150 watts
1 ohm - <75 watts
4 ohms - <750 watts
3 ohms - <563 watts
2 ohms - <375 watts
1 ohm - <188 watts
2 ohms - <950 watts
1 ohm - <475 watts
1 ohm - <1200 watts
1 ohm - <3000 watts
Originally Posted by PJK3,Jul 12 2007, 02:50 PM
what is the source for this information?
