Speakers cutting in and out
Old Oct 17, 2008 | 12:53 PM
604toaster's Avatar
Default Speakers cutting in and out
Hi all,
Was wondering if you can help out. I had my passenger window fixed at the shop.
Everything was fine. However, after it rained 2 days ago, my sound system doesn't work that well. The main speakers 6.5s cut in and out and the tweeters have major static. This is the same for radio and CDs.
I swapped out my alpine for the stock headunit and there is the same result.
Could the shop have messed up my wiring in the door speaker while changing out the glass?
Everything is stock except for the Alpine headunit.
I have to bring the car into the shop again to get the window aligned. Maybe I'll get them to take a look at it.
Keep in mind the sound system was fine. This started happening after it rained these past couple days.
Thanks all.
2004 s2000
Old Oct 19, 2008 | 12:52 PM
darkknight1999's Avatar
Sounds like one of the speaker leads is grounding out....
Old Oct 19, 2008 | 02:30 PM
Neutered Sputniks's Avatar
Check to see that all your speakers are tightly connected. Might have one loose and contacting the inside of the door.
Old Oct 19, 2008 | 03:07 PM
Oh and start with the door you had the window replaced in.
Old Oct 19, 2008 | 03:32 PM
Again, . The installers probably knocked one of the speaker wires loose or they didn't reinstall the door panel/speakers properly, etc.
604toaster
Oct 18, 2008 10:47 AM
plutonium239
Sep 25, 2007 04:31 AM
terpfan1
Mar 28, 2005 08:29 AM
hornyhonda
Oct 4, 2004 12:01 PM
2000celicaspeed
Sep 20, 2004 06:28 PM
