Subwoofer & amplifier problem
Old Jun 30, 2014 | 07:52 AM
  #21
gbozic's Avatar
Originally Posted by stupkid
found it with just a google search.
https://docs.sony.com/release/CDXGT2...tall_EN_ES.pdf
in box number 3. Remote is blue and white. If you still can't find it, get a volt meter and measure what puts out 12v when the radio is on. And the solid blue goes to antenna.
Thanks for that, the 12v one for mine is yellow! :/ should I still go for that one?
Old Jun 30, 2014 | 10:09 PM
  #22
Ragnarok043's Avatar
yellow is constant, red is accessory
Old Jun 30, 2014 | 10:56 PM
  #23
gbozic's Avatar
So I should go for the red one?
Old Jul 3, 2014 | 06:08 PM
  #24
yes the red wire turns off and on with the key
Old Jul 8, 2014 | 09:47 PM
  #25
hockeylfe11's Avatar
The sony unit will have a blue/white wire, which is an amp turn on wire. Its designed to provide 12v output when the radio is on, no matter what source you are using. However, if that's not working you can wire it to the red wire at the radio, which is accessory power. However, it's a good idea to get install a fuse in line with that amp turn on wire from the amp. You can pick one up from your local auto store for a few bucks. It'll be about 6 in of wire on each side of the fuse holder (make sure a fuse is in it That way if you ever run into issues it pops the fuse on that wire and not the radio, cig lighter, etc.
Ryans2kGPW
Jul 15, 2010 12:28 PM
cen_14
Jun 9, 2008 08:46 PM
s2kkyo
Nov 29, 2007 08:22 PM
User 71524
Mar 26, 2007 01:28 PM
h0ckeypunk
Feb 22, 2004 06:11 PM
