Testing - Multi Radio DCI for Eclipse HU's
Old Aug 26, 2003 | 06:50 AM
  #21
InsaneInNC's Avatar
Originally posted by modifry
.... but no switch for the folding top that I'm aware of.
That is what I was afraid of.
Old Aug 26, 2003 | 07:01 AM
  #22
InsaneInNC's Avatar
[QUOTE]Originally posted by modifry
[B]First question:
Old Aug 26, 2003 | 09:11 AM
  #23
modifry's Avatar
Honorary Member
Originally posted by InsaneInNC
With the top up, I have found in the past that there is very little need to readjust the volume due to speed, therefore, I would vote for Option "A".
I can only assume that you listen with the volume louder than I do, or maybe I want to drown out the wind/road noise more than you. I use volume compensation with the top up all the time. I actually have it set to adjust volume "the right amount" with the top up and I have to do a few manual adjustments (but fewer of them) if the top is down.
[QUOTE]Originally posted by InsaneInNC
[B]Now the $64,000 question, would the new "combo-button" interfere with the existing combo-button operations?
Old Aug 26, 2003 | 10:28 AM
  #24
InsaneInNC's Avatar
[B]I can only assume that you listen with the volume louder than I do, or maybe I want to drown out the wind/road noise more than you.
Old Aug 26, 2003 | 01:50 PM
  #25
afetsman's Avatar
Since my finger is only 2 inches from the volume control, I'll save my $20 and manually adjust the volume if need be . And I don't need my radio to know if my top is up or down yet, maybe I'll understand after I get a DCI.
How about the bass/treble controls for $10? I like that feature much better.
Old Aug 26, 2003 | 02:52 PM
  #26
modifry's Avatar
Honorary Member
[QUOTE]Originally posted by afetsman
[B]Since my finger is only 2 inches from the volume control, I'll save my $20 and manually adjust the volume if need be .
Old Aug 26, 2003 | 03:19 PM
  #27
modifry's Avatar
Honorary Member
. . . But before writing and rewriting to the eeprom, what is its life expectancy (i.e., how many times can you write/rewrite the chip)?
It's limited to only 100,000 write cycles, so if you put your top up and down 5 times a day, every day, it would wear out in 27 years. I'll make sure to change my email address by then so you can't return it for a warranty repair.
[QUOTE]Originally posted by InsaneInNC [B]How much do you think you can get for this?
Old Aug 26, 2003 | 04:03 PM
  #28
ruexp67's Avatar
Would you add this functionality for the Sony HU too? I might be willing to pay $20 to have my Sony DCI re-flashed.
Old Aug 26, 2003 | 05:32 PM
  #29
InsaneInNC's Avatar
Keep us posted as to what you plan to do. I will make a decision once you finalize the "new" DCI.
Old Aug 26, 2003 | 05:35 PM
  #30
InsaneInNC's Avatar
[B]It's limited to only 100,000 write cycles, so if you put your top up and down 5 times a day, every day, it would wear out in 27 years.
