Tweeter install in air vent/larger rears
Old Jul 27, 2001 | 07:57 AM
worm-s2k's Avatar
Default Tweeter install in air vent/larger rears
I recently read a post about installing separates where the tweeters were installed in the air vents and the mids in the door. Does anyone have pics/suggestions/and or experience with this install. I have a pair of Boston RC620's from a previous install....but I hate the look of a surface mounted tweeter and don't want to cut the door panels.
Second question: I never thought a set of 4" components could put out that much sound in the rear especially if the mid is installed low in the panel ala Lucid's mod. Does anyone have pics/suggestions/and or experience installing larger components such as the RC620's (6.5" components)...does it require cutting metal in addition to the plastic?
Old Jul 27, 2001 | 03:35 PM
lucid's Avatar
Anything larger than 4" will require metal cutting. But If you're willing it to shove good 4" components in there with an amp, it'll be louder than a sub in the truck. Its an awesome feeling getting the bass right through your back like that.
Heres an idea that I'm going to play around with:
On the left (passenger panel) is typically where you put your 4". I'm going to try putting another speaker where the vent is to have a dual setup. Of course you'd need an amp and how you hooked up the channels would be something to play with.
Old Jul 27, 2001 | 05:19 PM
ricosuave's Avatar
lucid--what are the exact dimensions of the hole including the width and depth?
Old Jul 27, 2001 | 05:50 PM
worm-s2k's Avatar
I'm thinking about mounting the speaker out from the panel a bit (i.e. putting a spacer of some type between the speaker frame and the plastic housing) to minimize the cutout size and to get a larger speaker diameter in the hole without a metal cut...Hmmmmm, have to think about that one and play with the sizes. Anyone try this?
Old Jul 29, 2001 | 02:14 PM
Pinky&Brain's Avatar
I put a set of tweets in my air vents..............IM NEVER DOING IT AGAIN!!!!!!!!!! Nuf said.
Old Jul 31, 2001 | 06:40 AM
Zippy's Avatar
Putting speakers in the air vent will make them extremely directional and will not allow the music to develop in the entire interior space.
Old Jul 31, 2001 | 06:52 AM
worm-s2k's Avatar
Any other location suggestions without drilling or cutting the door panel?
I also thought about mounting the tweet to a clip of some type and clipping it around the front of the door handle opening....then the plastic handle housing should hide most of the clip....still think it will be ugly....boy, I really need some of those custom molded tweeter pods that mold to the front of the arm rest.
Anyone seen any A-pillar replacements with built in tweeter pods?
Old Jul 31, 2001 | 08:22 AM
shaner's Avatar
The best part about mounting tweeters creatively in the A-pillar covers is they are cheap to replace... ~$25 each.
Considering dash replacements are $340 (that's where I mounted mine)... and each door is ~$265 each... the A-pillars are the best and least risky to work with...
...unless you never mess up... then cut away!
rad23racer
Mar 4, 2006 07:46 PM
beaudubbs
Sep 22, 2005 03:34 PM
s2khondaimport
May 12, 2004 11:01 AM
Ron H
May 16, 2003 09:40 PM
chardo
Aug 15, 2002 03:30 PM
