Voltage Drop problem
Old Feb 17, 2004 | 12:13 PM
PJK3's Avatar
glad to hear you got it working Sleepy... and yup... fuses can be freaky sometimes... especially on weird results like that... just keep an eye on it. it could be that the fuse was defective, but if something sparked the fuse - you may have other issues. whatever you do, don't just willy nilly up the fuse size to fix the problem... fuses are there for a reason, and that reason is to blow when something goes wrong.
i would definitely like to know if you develop dimming problems or anything.
wrenches on the terminals...
Old Feb 17, 2004 | 03:10 PM
Sleepy's Avatar
I know what you mean about the fuses - As a matter of fact I replaced the 60 amp fuse that was in place with a 50 amp fuse. I think I should be all good there... Thanks again!
Old Feb 20, 2004 | 09:05 AM
oneaudiopro's Avatar
You've gotten some good advise on places to start looking for the problem.....................I have seen fuses go "resistive" on many occassions and do just what you're describing. As far as caps go...............if you have an amp with a "regulated" power supply, you won't reap any benefits from a cap. On the other hand, if you own an amp with an "unregulated" power supply, a cap can definitely help your system regardless of amp power. In fact, it would have a more noticeable effect on a smaller amp than a larger one merely because it is easier to exceed the smaller amps rated power than it would be on a larger amp. Good luck and let me know if I can ever assist you in the future.
500 wrms does not need a capacitor.
Old Feb 20, 2004 | 09:53 AM
Sleepy's Avatar
My amp has a regulated power supply - good to know. I am set on ripping out the cap as soon as I get my deep-cycle battery. Thanks for the add'l info! A week or so has gne by since I replaced the fuse, and no problems to report to this point...
Old Feb 20, 2004 | 12:51 PM
modifry's Avatar
Honorary Member
[QUOTE]Originally posted by NFRs2000NYC
Caps are only necessary if the amplifier struggles to supply the subwoofer with power.
Old Feb 20, 2004 | 02:14 PM
Andy Kirk's Avatar
A discharged capicator can look like a dead short to a voltage source like an alternator. It is true that a slow charge MAY be built into the system to prevent this, I really don't know that much about how they setup the cap input circuit.
Andy
Old Feb 20, 2004 | 07:04 PM
modifry's Avatar
Honorary Member
^ Yes, a discharged cap can be considered a short circuit, but it's only discharged before you install it. They usually provide a series resistor for the installation because without the resistor the arc when you first connect power can melt the end off the wire/connector or start a fire.
Once the cap is connected, it stays charged at battery voltage, so when the car cranks up the alternator only has to bring it up another couple volts. It would be interesting to measure how much current it pulls right after the car starts, but I would be surprised if it's near the alternator maximum because the alternator voltage comes up gradually as the engine rpms increase.
I asked the question in case anybody had done any testing of alternator current when a cap is installed.
dominion
Jun 16, 2010 09:18 AM
Panda
Jan 3, 2007 09:05 PM
REVZ TO9
Jun 1, 2006 02:57 AM
C4SxM5
Jan 25, 2006 03:25 PM
bwalk22
Apr 13, 2005 03:20 PM
