Will These Component Speakers Fit?
Old Apr 14, 2011 | 02:56 PM
SIchodelic's Avatar
Default Will These Component Speakers Fit?
http://www.massiveaudio.com/store/pr...cat=303&page=1
Details
SKU SKURK6
Weight 25.00 Pounds
Speaker Size 6.5
Tweeter 28mm Silk Dome
Cone Glass Fiber
Sensitivity 90 dB
Frequency 65-20KHz
RMS Power 50-250w
Peak Power 500w
Impedance 4 Ohm
Crossover 12db External
Basket Cast
Depth 2.75"
Worried about the mounting depth. I remember finding the max depth the s2k can handle in the FAQ, but can't find it anymore. Sorry
I currently have the CK6, which performs SUPERB
but I have a chance to upgrade to their flagship model for cheap. Want to make sure it fits
the CK6s fit right now no problems, but it only has a mounting depth of 2.5"
Let me know please! I have to order them by tomorrow, lol
Old Apr 14, 2011 | 03:10 PM
irv_usc's Avatar
haha, i saw those on DIYMA too.
I'm thinking with the humongous magnet you'll need a pretty fat spacer, especially since the window comes down slightly angled.
With a 1" spacer you need to shave the back of the door panel.
Old Apr 14, 2011 | 03:53 PM
SIchodelic's Avatar
I'm using 3/4" mdf spacer right now. Should I pass on them?
I don't want to touch any trim pieces to make them fit. Only normal spacers
Old Apr 14, 2011 | 11:12 PM
SIchodelic's Avatar
after more research, i think they will fit
after digging up really old threads, some people say the stock mounting depth is 2.2"
3/4" spacer makes it ~2.95"
should be just enough without having to file the door card
awesome. These speakers are going to be BEAST
I don't even have an amp powerful enough to feed them
current amp is only 300/2 lol
Old Apr 15, 2011 | 08:12 AM
irv_usc's Avatar
let me know how it works out for you..
Old May 2, 2011 | 03:47 AM
roosty's Avatar
so did they end up working??? its between the RK6 or the CK6. if i can fit rk6 ill buy those. if not the ck6 will suffice... LET ME KNOW ASAP!!
Old May 2, 2011 | 02:48 PM
Kyushin's Avatar
Banned
I just installed these and they barely fit, I had to shave the inside of the door panel some where it has that foam rim. Also, the custom mounts were bout 1/2'' thick. By the looks of those speakers, they are alot more that 3'' IMO
Description
The Rockford Fosgate T2652-S features tweeter attenuation for up to 3 levels, and thus can produce sounds with much higher frequency levels with minimum loss. The DDC mounting technology used in this Rockford Fosgate 6.5 inch aluminum component speaker eases installation. This Rockford Fosgate car speaker has a frequency response of 55Hz-22kHz, and thus can produce most sounds with ease. With a power-handling capacity of 100 watts RMS (200 watts PMPO), the Rockford Fosgate T2652-S can produce higher sound output for extended periods of time with much ease. For easy fitting, this Rockford Fosgate 6.5 inch aluminum component speaker comes with a FlexFit basket design. The Rockford Fosgate car speaker is an excellent alternative if you are looking to bump-up your in-car entertainment system.
Brand Rockford Fosgate
Model T2652-S
MPN T2652-S
UPC 780687329235
Key Features
Size 6.5"
Type Component System
Elements 2-Way
Technical Features
Sensitivity 89 dB
Peak Power Handling 200 watt
Mounting
Top Mounting Depth 2.63 in.
Bottom Mounting Depth 2.52 in.
Enclosure Non-Enclosed
Mounting Diameter/Length 5.59 in.
Old May 4, 2011 | 09:32 PM
SIchodelic's Avatar
Ended up keeping my CK6s. Sorry I couldn't help you more.
Old May 5, 2011 | 04:50 AM
Chris S's Avatar
Would the CK6's work OK on a new Alpine/Sony HU's internal power? How difficult is installation, and does the spacer push the door panels out?
I have Polk MM6501's on the way, and am torn between their high efficiency vs. what I expect to be better SQ w/ the CK6.
mr5parkle
Feb 14, 2012 10:12 PM
Rdragon
Sep 12, 2010 06:22 PM
calcal
Mar 28, 2009 06:54 PM
The Gent
Jan 6, 2009 10:04 AM
CHUCKLIDDELL101
Feb 22, 2006 06:19 PM
