Flashpro Toda Tune vs Stock tune question
Old Jul 18, 2012 | 06:30 PM
xredjar's Avatar
Originally Posted by thesilverbullet
stock o2 is a wideband and he can street / E-tune with flashpro...
The stock O2 is a wideband and will get you in the ballpark, but the richer you go...the larger the deviation between AFR and AFR_Corrected values you see in FlashPro. Using a standalone wideband, you can really fine tune the AFRs. I've also got my wideband wired up so I can record it in FlashPro.
While a stand alone wideband is not required to get a good tune for a daily driver....it does improve accuracy. More power, and because the short and long term trims are within 3% most of the time.....I average more than 27MPG consistantly. I went from 221 / 156 on the stock O2, to 234 / 160 after tuning with the wideband. These numbers came off the same dyno.
There is value in a stand alone wideband, but it's up to the individual if it's worth it or not.
Old Jul 19, 2012 | 11:14 PM
06Estukay's Avatar
James,
PM me regarding tune.
Old Jul 20, 2012 | 07:11 PM
thesilverbullet's Avatar
actually the only debate is with the absolute values of the stock wideband. once u determine the offset u can tune to the desired a/f. hondata calulated about 1 point. further test by others with side by side comparisons to aftermarket widebands which were tigher ~.5 point difference. either way it would be a good idea to dyno with a/f readings to verfiy the stree tune and stock 02. placement of aftermarket wideband is key. idealy u would want to mount in stock location.
Old Jul 23, 2012 | 04:16 AM
xredjar's Avatar
My wideband is pretty close to the stock 02 as far as placement.
I can also confirm that the stock 02 is about .5 point off whay my wideband reads. I was doing the beta testing for ETunez, and both my tuner and I were interested in how much difference a wideband would make in the process. It's dialed in pretty tight....good power and I'm averaging over 28 MPG.
Different subject....
How is your throttle table when stuck in traffic and creeping along at low speed? I'm in the DC area, and I'm running a modded throtle table. I have played with it, and I either get it too soft (takes a much bigger blip when downshifting), or it's like a light switch when on/off throttle in traffic.
Old Jul 26, 2012 | 02:28 PM
its not bad creeping - i kept the values <=12.5% @<=4k near stock values to keep it drivable. for the 1.1-12.5% range i crank up the values from 4k+ so i have to keep the rpms above 4k to get the good throttle response. u have to keep adjusting to get them like you want it. im still adjusting... u got me tweaking now - lol
Old Jul 27, 2012 | 06:19 AM
xredjar's Avatar
lol.....it never ends. I tweak on it for a while...then go back. After a while...I start tweaking again....just can't seem to find the sweet spot I'm looking for.
Old Nov 26, 2012 | 07:24 PM
2000Audis4's Avatar
the toda tune was developed on a car with invidia N1 duals, cai, toda header and tp. depending on your mods the toda's 4100 vtec maybe too low. u can either raise vtec (~4800) or increase the pressure to make vtec only ingage down low at WOT. with any of these tunes u need to street tune the a/f and clean them up.
if you want better throttle response - u need to tweak the throttle plate table - take it easy on the first couple of columns or she gets jerky. otherwise u can crank it up and improve the throttle response to you preference.
here's my table and she rocks
500 - 1 3 8 13 17 35 40 50 60 70 80 90 100 100
1000 - 1 3 9 14 22 40 44 54 63 72 81 91 100 100
1500 - 2 4 9 15 27 44 49 57 66 74 83 91 100 100
2000 - 2 4 10 16 32 49 53 61 69 76 84 92 100 100
2500 - 2 4 10 17 38 54 57 64 71 79 86 93 100 100
3000 - 2 4 11 18 43 58 61 68 74 81 87 94 100 100
3500 - 3 5 11 19 48 63 66 71 77 83 89 94 100 100
4000 - 5 10 15 20 53 68 70 75 80 85 90 95 100 100
4500 - 6 12 18 24 59 72 74 79 83 87 91 96 100 100
5000 - 8 14 21 27 64 77 79 82 86 89 93 96 100 100
6000 - 9 16 24 31 69 81 83 86 89 91 94 97 100 100
7000 - 11 19 26 34 74 86 87 89 91 94 96 98 100 100
8000 - 12 21 29 38 80 91 91 93 94 96 97 99 100 100
9000 - 14 23 32 41 85 95 96 96 97 98 99 99 100 100
10000 - 15 25 35 45 90 100 100 100 100 100 100 100 100 100
I just bought a Flash Pro and I came across this, and used it..it does rock i feel a good gain. do you have any other tables and how did you come up with those numbers. worked great
Old Jan 6, 2013 | 07:22 PM
uLmighty's Avatar
Since this is latest thread about hondata, I have a question. I have an ap2 08 with FIKP, header back test pipe/single exhaust. So I was wondering whats the diffrenece between reflash and flash pro? From what I'm understanding on their website all I need to do is send my ECU and they'll tune it for me for $295 without buying the hondata?
http://www.hondata.com/reflash_s2k_06.html
Old Jan 7, 2013 | 12:54 PM
ungucpho's Avatar
no, the reflash is just a generic tune. the reflash is just that, reflashing the ecu with a generic tune, with no ability to modify the map. the flashpro allows you to reflash and tune the ecu on a dyno or through e-tuning
06s2kid
May 20, 2016 01:44 PM
merckx racer
Feb 17, 2012 09:33 AM
DG
Mar 17, 2011 10:02 PM
dedonderosa
Apr 30, 2010 02:46 AM
