RPM Stumbles after revving
Old 08-02-2018, 09:30 PM
Snakecharmer's Avatar
Default RPM Stumbles after revving
I think this subject has been broached over and over again but nothing I have read so far has helped me cure my problem. So here goes......
Rev the engine and when it returns to idle the engine sometimes shudders as the revs drop to around 60r7k for a second. Same thing happens when I pull away without giving it plenty of revs.
I have set the TPS to as near to 6% as possible (5.9%) I have thoroughly stripped and cleaned the IAC valve. I have replaces the MAP sensor and thoroughly
cleaned the throttle body and adjusted the throttle cable. I have re-learned the ECU god knows how many times and my code reader shows no fault codes. Both O2 sensors read between 0-1volt. The car has 54,000 miles and otherwise runs fine, on the cam and off (VTEC). Valve clearances also double checked. It has done this since I purchased it 3 years ago and I would really love to finally sort out the problem once and for all. It seems odd that it does not do it every time the engine returns to idle. Please help!
http://www.youtube.com/watch?v=4dd_V...ature=youtu.be
Snakecharmer
08-11-2018 04:25 AM
FIRSTCAR-S2K
09-30-2015 03:06 PM
schwissig
08-14-2013 09:07 PM
gdmedic
11-27-2009 04:04 PM
S~Factor
19
04-17-2008 08:28 AM
Quick Reply: RPM Stumbles after revving
