Using the RSX wideband with the Kpro
Old Nov 12, 2010 | 07:45 PM
  #101
jaundice's Avatar
Yep. Give me a text sometime. I am pretty decent with electronics.
Old Dec 1, 2010 | 04:07 PM
  #102
0piston's Avatar
how can you tell within the Hondata kpo software if you are running a PRA or a PRB map?
thanks
Old Dec 3, 2010 | 04:17 AM
  #103
Garrett_si's Avatar
thanks
you select the vehicule, S2000 Ap1 as a base map
Old Dec 3, 2010 | 08:21 AM
  #104
WLAURENT's Avatar
thanks
Look on the closed loop tab:
If you can select "Use Secondary O2..." it is a PRA map
IF you can not select it, it is a PRB map
Old Dec 3, 2010 | 08:52 AM
  #105
Garrett_si's Avatar
S2000 map have VTC map lock
Old Dec 23, 2010 | 11:44 AM
  #106
nnausmann's Avatar
Originally Posted by Topillogic,Jun 15 2010, 02:57 AM
Well, after an epic six hour google / trawling forum posts / trying to read through Japanese PDFs session... I found it.
The hardest part was getting the part number, but even then nowhere wants to sell these things in sub 5000 lots. Until I found Eastern Beaver Co. these guys have a paypal account and will ship single units or even just the spare pins and seals.
It's a Sumitomo HW Series sealed female connector. P/N F(6189-0132)
http://www.easternbeaver.com/Main/Elec__Pr.../SMHW/smhw.html
Just wanted to give a little feedback about my experience with eastern beaver.
I had to replace the wideband sensor and harness plug so I ordered the Sumitomo HW Series sealed connector set. Part# 4P090WP-HW. Came to about $8.50 shipped from japan. Ordered it on Dec 13th and just got it today 23rd.
This connector is an exact match to the oem honda one.
Old Dec 23, 2010 | 08:27 PM
  #107
DFWs2k's Avatar
Ok i'm trying to make a comprehensive list of what is needed for this, maybe it can get added to first post
So for this mod you need:
10 ft of 4 different colors of wire
http://www.connectworld.net/cgi-bin/.../CAB004-18SPKR
10 ft of wire loom to protect wires in engine bay (WL910) (50 ft, cheapest I could find quickly)
http://www.cabletiesandmore.com/blackloom.php
or would this be better? http://www.rrdatatelecom.com/cgi-bin/rrdata/HE1-4-BK
ECU pins (5)
http://www.newark.com/tyco-electronics-amp...211?Ntt=85C1211
30 AMP automotive relay (like this? do you just leave the 30 amp automotive relay freestanding, or is there a different type you can get that is enclosed? is that everything?)
http://www.allelectronics.com/index.php search for "RLY-351"
RSX extension harness (4P090WP-HW)
soldering iron and solder, electrical tape, a few male and female spade connectors
Old Dec 23, 2010 | 10:26 PM
  #108
Fierc3's Avatar
I think the 4 pin weatherpack and the 6 pin molex connector were just to make the sensor plug into something. if you get the rsx extension stuff from eastrenbeaver, the sensor should just plug into that, and that will go straight to the ecu/relay. correct me if im wrong.
Old Dec 24, 2010 | 06:49 AM
  #109
DFWs2k's Avatar
looked at topillogic's picture and agree, thanks!
Old Dec 31, 2010 | 02:58 PM
  #110
nnausmann's Avatar
I have everything hooked up and running. But I am getting a code "PO141 secondary o2 sensor heater circuit malfuntion"
Do I need to check something in Kpro?
