Using the RSX wideband with the Kpro
Old Dec 31, 2010 | 03:05 PM
  #111
WLAURENT's Avatar
Originally Posted by nnausmann,Dec 31 2010, 03:58 PM
I have everything hooked up and running. But I am getting a code "PO141 secondary o2 sensor heater circuit malfuntion"
Do I need to check something in Kpro?
Are you still running a PRA map?
You have to unselect "use secondary as primary" and tell it to use the primary wideband sensor.
Old Dec 31, 2010 | 03:07 PM
  #112
nnausmann's Avatar
Nevermind I had "enable emissions error checking" on.....
Old Dec 31, 2010 | 03:08 PM
  #113
nnausmann's Avatar
No running PRB map.
Old Jan 19, 2011 | 11:27 AM
  #114
jaundice's Avatar
The 06+ came with it already. We have to modify
Old Feb 17, 2011 | 07:08 PM
  #115
Fierc3's Avatar
How do you make a PRB map??
Old Feb 18, 2011 | 05:45 AM
  #116
nnausmann's Avatar
I just opened a PRB map and copied every screen over from the PRA map. I have not driven the car yet or tuned it, just started it and let it idle. I could send you my map to get you up and running if you want.
Just understand it is a untuned base map and I am NOT liable for damage to your motor.
Let me know.
Old Feb 18, 2011 | 06:30 AM
  #117
Fierc3's Avatar
Sounds good, You have a pm.
Old Feb 18, 2011 | 03:08 PM
  #118
JustinC's Avatar
Let me know.
This is how I started out and the values on a PRA map are different than a PRB map so you have to be careful
Old Feb 18, 2011 | 04:12 PM
  #119
DFWs2k's Avatar
that's pretty crazy that there is absolutely no way to convert from one to another
Old Feb 18, 2011 | 04:57 PM
  #120
nnausmann's Avatar
That was the short version. How I realy did it was by printing every screen shot of the PRA map till I had a big book. Than opened the PRB map and manually enter every value till I had a mirror image of the PRA map, with the exception of a couple of values.
Took a while but I was at work and got paid to do it.
