Using the RSX wideband with the Kpro
is the new one still called a tunerview?
i guess so, the tunerview RD 1
damn
http://www.hrtuning.com/pages/category/tunerviewrd1
damn
Just installed the RSX wideband and only issue so far is when I start the car, sometimes it doesnt register the sensor and will pop a CEL after a min or 2. If I kill the car and restart it the sensor kicks in after about 10 secs. I R CONFUSED.
Maybe a bad sensor? It does take about 10-15 seconds for the sensor to warm-up, but all of them are this way and should not pop a CEL. After a minute though, it will. Maybe check all your wiring. The sensors have a heater in them, so if you could get ahold of another O2 sensor, might switch it out and see.
I went through an OBDII inspection in Texas with KPro and the RSX wideband mod. No issues. In Texas, they are just checking for codes and making sure all EPA/Emissions stuff is functional (which KPro hides, LOL) when they connect to your OBDII port. All states are different though, so check in your area.
Yeah, we are trying to hash out some options right now, JustinC helped me install it, we are gonna try a few things and see what we come up with. The really odd part is that it will not see the sensor the 1st time i turn on the car, no matter what, i tried everything. But as soon as i turn it off and then back on it kicks in after 5 seconds or so, every damn time, its wierd.
Originally Posted by DFWs2k' timestamp='1300763918' post='20384685
How did yall hook up the wires (solder, etc) and did yall find any good cheap places for parts?
Is your relay good? Have any others laying around to try out?
