Using the RSX wideband with the Kpro
Questions¿
where are you guys mounting these relays?
I was thinking of using a box, about the size of a cigarette pack, & securing the relays in there for better mounting.
(also in case a relay takes the day off, easy access/replacement)
This Hella Relay looks like its a heat sink too, how hot does it get?
^^How did you wire it up freezingcoffee?
^^When does it initially start to heat up?
Originally Posted by hybridsol' timestamp='1308454173' post='20696952
[*] The ground from (85) on the Hella relay *may* need to be connected to the ECU ground for the relay to work. The relay operates by switching the ground at (86). This must be the same ground at (85)
No mounting- They 'fit' on the sheemetal ledege under the kick panel- where the carpet ends- and the carpet keeps them in place (how I did it)
Thats good to know. I wanted to ask you if you had any problems. I wired as Justinc and Topillogic did. I don't think any of us have had any problems.
Only thing I get occasionally is a slow response from O2 heater code if I leave it out overnight in the winter. That may just be a problem with my specific sensor. Either way I just clear the code with the Tunerview once it's warmed up for half a minute.
Not sure what board rev. I'm running, bought it maybe a year and a half ago, now.
