*UPDATE ON PG2* TURBO EMISSIONS
Old Mar 21, 2009 | 06:41 AM
  #31
SC-S2000's Avatar
how much rewiring did you have to do for your injectors?
yes you can leave the uego in there its not a vital part its just informative to you and your tuner.
Old Mar 21, 2009 | 01:12 PM
  #32
bassamdp's Avatar
[QUOTE=CourageOO7,Mar 20 2009, 03:04 PM] I'm quite sure this device would be quite illegal to manufacture and it sounds like a (potentially) 50 state class action lawsuit waiting to happen.
Old Mar 21, 2009 | 03:23 PM
  #33
CourageOO7's Avatar
Originally Posted by bassamdp,Mar 21 2009, 04:12 PM
I think you just saved my ass from a class action lawsuit!!!
Thank you in advance??!
So far, for my situation, I've concluded;
first, remove the AEM EMS
- install a Greddy E-Manage; a piggy-back ECU which allows the OBDII port to function.
http://www.ultimate-racing.com/Products2/S...pgradeKit.shtml
I essentially have an Ultimate Racing Turbo Kit, this originally came with a Greggy E-Manage, but upgraded to the AEM EMS option. I do have connections with one through S2ki (THANKS TO ALL OF YOU AT S2Ki!).
- run/install the base tune map for my S2000 for the E-manage. The base map was designed for 600cc injectors, I have 550's. hopefully I can adjust that. Also, I have an ultimate racing 3" catback exhaust, cleard factory cat, and the included downpipe from my turbo kit.
- Ensure the vehicle is not throwing any check engine codes.
- Go to emissions, and hopefully pass?
*** Please add any feedback, or add to my steps above if I've left anything out.
THANK YOU ALL
You're going to need to drive around a good bit so that the ecu can log enough heat cycles to pass emissions.
Also, make sure the stock ecu doesn't throw any codes regarding those bigger injectors. I know that, without the emanage, the stock ecu will only support up to 440cc injectors but I think you should be alright with the emanage.
Cheers,
J
superslows2k
Nov 11, 2009 06:45 AM
bassamdp
Oct 24, 2007 01:46 PM
SilvCF2k
Jan 16, 2007 06:53 AM
s2000honduras
Jan 26, 2006 08:05 PM
