382 hp on 10 psi of boost
Old Jun 28, 2008 | 05:46 AM
MrHonda's Avatar
Default 382 hp on 10 psi of boost
My setup is an '05 with a KraftWerks high boost kit (10 psi) with stock header, cat, and exhaust.
In addition to the KW SC kit, I supplied:
RC 650 cc injectors w/plug and play clips - about $450
Walbro fuel pump - about $100
Hondata K-pro ECU - $1800
Hondata intake gasket - $60
Valve cover, sensors, etc. for K-pro conversion - about $300
ACT HD pressure plate - about $525
Stock disk - about $120
Stock release bearing _ about $125
Spark plugs, oil filter, Mobile 1 oil - about $60
Tuning - $350
Sub Total $3885
Kit $5495
Grand total $9380
I removed the engine because I was replacing the clutch and had initially intended to install a thicker head gasket. Lowering the compression is not necessary or advisable. The supercharger install was done after the engine was re-installed. Removing the engine is not required.
Protecting the paint
Driveline removed
Owner supplied parts (Injectors and K-pro not received yet)
Kit parts
Sensor install
Clutch
Intake gasket
FMIC install
Hondata K-pro install
Pictures of engine bay coming (forgot where I put them )
Scan of original printout from last dyno test
Overlay of KraftWerks kit results on my previous Comptech vs Stock results
Taking down $60k+ cars at the track, priceless...not really just the price of an S2 plus $9380, but the feeling IS priceless.
Old Jun 28, 2008 | 06:58 AM
Slows2k's Avatar
Did Ed do the tuning at Balanced?
Old Jun 28, 2008 | 07:11 AM
s2000442's Avatar
What was the installed price? Those numbers look like parts only?
Old Jun 28, 2008 | 07:31 AM
GrandMasterKhan's Avatar
He did all the install himself. So no labor other than tuning.
Old Jun 28, 2008 | 07:39 AM
EternalLx's Avatar
How are your IAT in different conditions? Track, cruising, bumper to bumper traffic.
Old Jun 28, 2008 | 08:06 AM
RollerBoy's Avatar
simply awesome! Kudos to you MrHonda!
Old Jun 28, 2008 | 08:11 AM
MrHonda's Avatar
Yes Ed @ Balanced Performance did the tuning.
Old Jun 28, 2008 | 08:13 AM
MrHonda's Avatar
I haven't datalogged different driving situations but during the tuning Ed was impressed that the IAT was not going up at all during all the runs. When I have more specific info I'll post it.
Old Jun 28, 2008 | 09:10 AM
5power's Avatar
Sick, power is so linear, no spikes at vtec at all. That graph is fun to look at better if it made 400 it's close
Old Jun 28, 2008 | 09:12 AM
5power's Avatar
how does it feel compare to the old comptech? Better yet a turbo car? I might have to get rid of the snail.
