adding more boost with CT SC and need some input
Old May 13, 2011 | 11:26 AM
s2000Junky's Avatar
Originally Posted by S2K-F8
I have a SOS 3.2" pulley and belt for you if you want it. Had it on my SC'd AP1 for a couple thousand miles before I sold it. Gonna send you a PM.
Scott-
There you go, perfect!
Old May 13, 2011 | 12:16 PM
erikvanden's Avatar
Originally Posted by s2000Junky
Originally Posted by erikvanden' timestamp='1305312755' post='20572975
[quote name='s2000Junky' timestamp='1305309516' post='20572701']
[quote name='erikvanden' timestamp='1305308583' post='20572629']
[quote name='s2000Junky' timestamp='1305271721' post='20570930']
Go through SOS (Science of speed) for the pulley, and map sensor.
Should i just get the 12PSI (3.0) pulley then?
I also just wanted to make sure that the map sensor is absolutely necessary. I don't mind paying for it if I have to but I am willing to bet with my set up that a 11 or 12 PSI pulley wont make over 10 PSI of actually boost. With my AC and larger heat exchanger I am maybe making 4.5 - 5lbs with the 6PSI pulley and that is at 9K.
your input is greatly appreciated.
You will need it, there is some inconstancies with the boost chart/pulley size. With my A/C set up Novie 1000, same as yours, I see 13psi at 9k with a 3.2" SOS pulley. If you have an ap2/8k rev you will make 1psi less. With a 3" Pulley you could touch 15psi at 9k. This is based on Sea level. If you are higher elevation you will see less boost.
[/quote]
should I get the 3.4in pulley then? It seems like the 3.2 is the best but they don't have it anymore
[/quote]
SOS doesnt have a 3.2" in stock anymore for the NV1000?
To clarify, what rpm will you be revving to? And you have the comptech A/C (water to air after cooler) with larger heat exchanger right? Or are you running an fmic?
[/quote]
9K. yes is the the comptech A/C with the larger heat exchanger. It mounts on the front but it is still air to water.
And I am not sure why the don't offer it anymore. It just says it is not available and has for some time http://scienceofspeed.com/products/e...00_SC_pulleys/
I was going to call SOS but I got one that Scott (s2k-f8) had
Old May 13, 2011 | 12:20 PM
Kyushin's Avatar
Banned
Just be sure its the correct pulley, the novi 1000 and 1200 do not use the same pulley
Old May 13, 2011 | 12:25 PM
Moddiction's Avatar
Former Sponsor
Shouldn't really lose boost with an aftercooler. Not like the fmic's. A free flowing exhaust can lower the boost you see though so maybe that is why.
Old May 13, 2011 | 01:27 PM
erikvanden's Avatar
I'm pretty sure Scott had the ct sc before the started making the other blowers available. Either way i checked the picture he sent me and it said novi 1000 on the pulley. Thanks for bringing that up though. I didn't think about that.
[/quote]
that could be it. I'm not to worried. I'll just get the map sensor if that is all it is. I will probably bring it to fullblown since they are located close to where I live and I believe they sell the map sensors as well.
Old May 13, 2011 | 07:04 PM
s2000Junky's Avatar
Yeah there is only 1/2psi loss with our A/C. A larger heat exchanger has no effect, or relation to boost pressure. A typical ultimate racing fmic will lose 3-4psi on our set up, such a waste. You will make between 12-13psi with the sos 3.2" pulley and should reach the top end of your power goals no problem as long as everything else is sound.
Old May 13, 2011 | 07:14 PM
erikvanden's Avatar
sounds good. Ill just use the stock fuel pressure regulator.
I have the AEM EMS, Id1000 injectors, and pulley with belt on the way. Ill pick up the map sensor soon also.
I still have the stock ap1 retainers but checked them last night and where fine so wasn't going to change them out since I haven't tracked the car yet. Probably going to get the newer banjo bolts before I put the new pulley on though. Other than that it looks like i'm ready to rock and roll. I just don't want to make to much power because the SOS clutch can only hold about 400rwhp
Old May 13, 2011 | 07:21 PM
s2000Junky's Avatar
I'm running the sos clutch, it will hold everything the Novi1000 can put out. No worries.
OemEF
Apr 14, 2013 01:58 AM
CourageOO7
Oct 1, 2009 11:19 AM
s2kadrenalin
Dec 24, 2008 03:56 AM
s2000Turkey
Aug 18, 2008 07:58 PM
mkell
Nov 4, 2004 01:36 PM
