AEM check engine light question
Old Mar 10, 2014 | 11:37 AM
s2kseven's Avatar
Default AEM check engine light question
I have AEM Ems and Ap1 - I'm doing some cluster gauge swapping.
Anyone here knows what pinout in AEM EMS is the MIL LIGHT wire (Engine check light).
I don't know if AEM has or no MIL LIGHT pinout.
thanks
Old Mar 10, 2014 | 06:42 PM
biohazarde's Avatar
What are you needing it for? AEM wont throw any codes that would light up the CEL like the stock ECU does
Old Mar 11, 2014 | 03:20 AM
s2kseven's Avatar
Thank you....that's good enough to know. I have a CEL wire in my new gauge and has a CEL light.
Now that I know AEM does not handle CEL code which is good for me to know.
Old Mar 20, 2014 | 09:52 PM
speedemon53's Avatar
yea on my AEM V1 the only thing my check engine light is used for is for if the car starts to overheat set to come on at 235 degrees, john at innovative motorworks did it during the tune session
Old Mar 22, 2014 | 04:14 PM
AusS2000's Avatar
AEM doesn't have OBDII which means the idiot light won't work like it used to.
That said, you can set it up to work however you like. As the AEM doesn't drive the ECT gauge many use it to show an overheat (as above) but you can configure it to light on any condition you like. Just wire it to one of the available spare outputs.
Old Mar 23, 2014 | 05:21 AM
Moddiction's Avatar
Former Sponsor
I have mine set to come on for overheating as well.
Old Mar 23, 2014 | 05:43 AM
starchland's Avatar
How can this be done? Thx
Old Mar 27, 2014 | 05:58 PM
danielsun0922's Avatar
I just got a tune today, I'm also running aem v1 I was told to not worry about the stock temp gauge because of the fail safe system on the ems the check engine light will only come on if your car temp reaches 241 degrees F. Hope this helps
Old Mar 27, 2014 | 06:29 PM
AusS2000's Avatar
Purchase an ECT to get you temp gauge working. No one in their right mind runs without a temp gauge.
http://www.modifry.com/products/ect/index.htm
Spec_Ops2087
Oct 27, 2010 12:49 PM
dsddcd
Mar 14, 2009 12:29 PM
Planets
May 11, 2008 09:52 PM
QUICK_AG
Jul 31, 2007 04:35 PM
beroznikmal
Oct 8, 2004 12:46 PM
