AEM EMS users
Old Aug 8, 2005 | 02:33 PM
FF2Skip's Avatar
Default AEM EMS users
I've been told that some software doesn't like the serial to USB adapter. I was wondering if anyone has experienced this first-hand as I am about to purchase a laptop for this application as well as for the children's schoolwork.
TIA.
Old Aug 8, 2005 | 02:40 PM
Scorpion's Avatar
I'm using one, and it works ok. There are some issues. Most annoying is that evertime I use it I first have to find which COMM port the computer decided to put on it. Not a big deal but like I said annoying. The second problem I have is that if the computer goes into sleep/hibernate/any other condition other than ON it locks up and I have to reboot the computer. Other than that it works great. I've never had it flake on loading a map or reading information from the EMS.
Old Aug 8, 2005 | 02:53 PM
FF2Skip's Avatar
Thanks for the quick response. I'm guessing then that you wouldn't let the fact that a laptop doesn't have a serial port keep you from purchasing one if it had all the other features you needed/wanted except the serial port?
Old Aug 8, 2005 | 03:52 PM
Silver S2k4's Avatar
I got one as well. Mine always works on port 5 and going into sleep thing is a pain like scorpion mentioned. Works fine though. Pretty much none of the new lappy's have a serial port so your choice would be limited.
Old Aug 8, 2005 | 03:53 PM
f20kills's Avatar
Same here.
I just close and save before I unplug it and then power down.
This helps it from freezing.
Old Aug 8, 2005 | 03:54 PM
Sideways's Avatar
I couldn't get mine to work with a new laptop that didn't have a serial port. I was unable to get the USB to serial adapter to work correctly with the EMS. I ended up getting an older second hand laptop to work with the AEM EMS. You should be able to pick one up inexpensively.
Old Aug 8, 2005 | 04:09 PM
FF2Skip's Avatar
Thanks all. Dell's 600m has a serial port, however, I'd like to be able to have more buying options.
Old Aug 9, 2005 | 10:50 AM
The usb adapter should come with some software. You must install the drivers and then switch around the ports. It didn't work for me at first either.
Old Aug 9, 2005 | 04:03 PM
Stratocaster's Avatar
Skip
Header?? Replies to my PMs?
Old Aug 10, 2005 | 09:34 PM
FF2Skip's Avatar
Originally Posted by Stratocaster,Aug 9 2005, 07:03 PM
Skip
Jeff, I have no pm's from you, however, I just sent you one and will follow it up with an e-mail version. Your header is going out tomorrow via FedEx unless I hear from you after reading my message. Rick is apparently on vacation.
fuentes_s2k
Oct 14, 2012 10:12 AM
scottieboy561
Jan 22, 2009 03:33 AM
passmans2kny
Aug 1, 2008 04:22 AM
Spec_Ops2087
Oct 27, 2007 07:43 AM
bgbfflochp
May 23, 2004 03:20 AM
