AEM METH KIT Heads up
Old Jan 27, 2011 | 10:11 AM
  #41
s2000Junky's Avatar
Originally Posted by o'malley_808,Jan 27 2011, 10:51 AM
I'm going the solenoid route also. I wonder if the pump can handle being ON all the times with the ignition of the car or whether it will burn out?
The pump will not stay on, it only stays on long enough to get up to full pressure, and then the solenoid keeps it there, so the system is primed at full pressure and ready to go. Once the injection is triggered the solenoid releases that charge and the pump fires up.
Old Jan 27, 2011 | 10:14 AM
  #42
boostedf22c's Avatar
Originally Posted by s2000Junky,Jan 27 2011, 03:06 PM
6000 miles? I put that many miles on my car in 4 months, but what ever. Your right, I must not know what I’m talking about. I find it interesting that several people have noticed the same delay problem that I did 2 years ago, but know one could explain why. There is a reason for it, and I’m explaining the mechanics of why that is…
I'm just giving my personal experience with the car, my power levels, how I drive it, what kind of power it made, what kind of 1/4 performance it had, all with no problems.
Yes, 6000 miles, in 1 summer (about 4 months).
I never once questioned your intelligence. It's actually quite the opposite. I must not be as sensitive though.
Old Jan 27, 2011 | 10:15 AM
  #43
s2000Junky's Avatar
That’s fine, share your experiences, but I at least put my own kit in, so let’s not get too far ahead of ourselves. Its not a dick waving contest, we don't care how big your numbers are, it’s irrelevant to the discussion. We are all using a form of injection system, most seem to be using the AEM progressive controller which I have direct experience with also, so let’s pool our experiences and share what we know.
Old Jan 27, 2011 | 10:16 AM
  #44
siadam's Avatar
I don't see the delay being an issue, however I didn't have alot of seat/driving with it, but from what I saw, it activated pretty quickly once boost hit (green led lit up).
I understand this is no indication of flow, just power to the system, but from what I saw, I always had fluid in my line when I was changing nozzle, or what have you, as soon as I would tip the line, it would pour out.
However, my pump is in my drivers side fender, and the lines are fairly short, I didn't install it in the trunk like most, I would imagine you would have a pretty lengthy delay.
Old Jan 27, 2011 | 10:19 AM
  #45
That's all I was doing. Stating my experiences, with my power levels and performance.
The power numbers and performance are irrelevant? Hmm. Ok.
Maybe you should develop your own meth injection system since you seem to know so much about it. lol
At least you put your own kit in? What is that supposed to mean? You act like that's hard. Haha. The directions that AEM included with the kit makes it so easy a caveman could do it.
Old Jan 27, 2011 | 10:27 AM
  #46
s2000Junky's Avatar
Originally Posted by boostedf22c,Jan 27 2011, 10:57 AM
I don't understand why you guys think you have to reinvent the wheel. If there was a design flaw in AEM Water/Meth kit, I guarantee I would've destroyed my motor. I don't think there is a single person on here that made the kind of power I did on that kit, and for as long as I did. It wasn't a one shot wonder either. It was 40+ 1/4 mile passes, it was 6000 miles on the street, and tons of dyno pulls. The kit is solid, cheap, and works. I also used the recommended 50/50 water/meth mix. No reason going against what the engineers that designed the system recommend.
You don't need to build some elaborate, expensive, complicated system. It's not needed.
I mean seriously, what kind of power are you guys wanting to make on the kit? Is 700whp not enough, is 9 second 1/4 pass not enough? Honestly, at that point, you'll need race gas to continue past that HP level.
Ugh. It’s not about how much power you want to make, it’s about having a kit that doesn’t have a delay when you call it to inject. This single fault is the nature of the progressive type of system, there are several other "types of systems that don't operate this way. So if your seeing this delay situation and it’s a problem, then understanding why its there will help someone make the appropriate choice on resolving it. Their are alternatives, good for all power levels. I provided a link in the other thread where I have sourced my parts to replace the progressive controller, but retain the pump and tank. Cost is less then the cheapest AEM kit, and will function without a delay.
Old Jan 27, 2011 | 10:31 AM
  #47
s2000Junky's Avatar
Like I said, I am… its not hard, just takes a little research. There is allot of information out there. I recommend you do a bit more yourself if you want to have anymore valuable input to the discussion. Thats great you have had some good results
Old Jan 27, 2011 | 10:32 AM
  #48
What I am saying is, if this delay that you speak of is actually a problem, don't you think I would of noticed it pushing things as hard as I was.
My motor was relying on the water/meth for it's survival. Your motor clearly isn't. So how would you even know if this were a potential problem? Assumption?
Are you just assuming that the slight delay is actually bad? So have the controller turn on the system before you need it? Problem solved.
I don't see this as a problem, nor does AEM, or they wouldn't of released this kit. But to each their own.
Old Jan 27, 2011 | 10:34 AM
  #49
Nah, I'm done with water/meth. It worked great, but 700whp isn't enough. Time for race gas.
I'm glad you know my background and my knowledge base.
  #50
s2000Junky's Avatar
Sure, but you didn't It doesn’t help support someone cause when they don't do their own work. No matter the difficulty level, going through the process yourself, gives you a different prospective on the subject matter.
