Anybody know what the output voltage is for the MAP?
Old Nov 25, 2003 | 06:33 AM
Gernby's Avatar
Former Sponsor
Assuming the MAP output is 0-5V (right?), is the output going to be 0V at 1 atm. (WOT, no vaccuum), or 5V at 1 atm.?
Old Nov 25, 2003 | 07:28 AM
modifry's Avatar
Honorary Member
Actually it's 200mv (.200 volts) per PSI. Full vacuum is 0v, which you will never quite reach, and 1 Atm is approx 3v.
The sensor will supposedly read up to 1.5 atm and I know it will go to at least 5.5 psi of boost because I put a voltmeter on it to measure boost on my Comptech SC.
Old Nov 25, 2003 | 07:48 AM
cbender's Avatar
I can verify that the stock map sensor will read higher than 5.5psi of boost. I run the stock sensor with 7-8 psi of boost with the AEM EMS and it works fine. When I overboosted at Portland International Raceways in September, my EMS logs showed that the sensor read up to 10.5psi of boost -- when the boost gauge went off the map. Given that, I suspect it tops out about 1.75 bar.
CB
_________________
C. Bender
2001 Silver/Black
Turbonetics TO4B 60:1 Ball Bearing Turbo; Tial 46mm Wastegate and 50mm Blowoff Valve; GReddy EGT and Boost Warning Gauges; Speedcraft Front Mounted Intercooler, Mandrel Bent Tubing, 3 Inch Down Pipe, and 3" Stainless Exhaust; A'PEXi N1 Mufflers; AEM EMS, Fuel Pressure Regulator, and Wideband O2 Sensor; RC Engineering 550 Injectors; Holly 250 Forced Induction Fuel Pump; Oil Filter Relocation Kit with Stainless Steel Lines; Clutchmaster Stage 3 Clutch; Toda Lightweight Flywheel; Mugen Radiator Cap, Thermostat, and Fan Switch; Upgraded Oil Bolts; Hecash Brake Ducting; Competch Stainless Steel Brake Lines; WorkMeister S2R 18" Wheels; Spoon X-Brace; Muz Shift Knob; Lucid's Front and Rear Speakers; 2002 Stereo Head Unit; Rick's Front Badge; JDM Clear Side Markers; Uber Cool Nurburgring Decal
Old Nov 25, 2003 | 10:07 AM
Gernby's Avatar
Former Sponsor
So 0-4V would be all that the ECU would ever expect to see from the MAP on an NA setup?
Old Nov 25, 2003 | 12:29 PM
AusS2000's Avatar
0-2.9V is all the ECU would expect. Any higher and it pulls ignition timing drastically.
conors2k
Oct 7, 2014 05:01 PM
EK9MAX
Aug 20, 2014 07:20 PM
CourageOO7
Feb 20, 2008 05:15 PM
freshs2k
Nov 15, 2007 01:16 AM
spoolins2k
May 26, 2007 02:00 PM
