Broke my transmission
#112
#113
Originally Posted by Spoolin' timestamp='1405468609' post='23245477
[quote name='Phill24' timestamp='1405455498' post='23245222']
[quote name='Spoolin' timestamp='1405453952' post='23245180']
[quote name='boostedf22c' timestamp='1405447454' post='23244993']
It's going to be similar to this pic below (trans might be different). The plate you are buying bolts up to the stock bellhousing. Then that plate has the bolt pattern for the transmission.
Do they make a kit similar to this for the GForce 6 speed? I'd rather have that over the 4 or 5 speeds since mine is more wkend warrior on the streets with ocassional 1/8 mile track runs. Can we get the shifter to look good in the stock location with the clutch assist unit in the event I did go that route?
What's your thoughts on the V160 swap?
[/quote]
Yeah, the T56 but I think the Gforce unit is setup to shift good at high rpm, like 10k rpm. I could be wrong though. Can it be setup to bolt to the stock bellhousing like what Carey posted? That would be the ticket right there.
[/quote]
U don't have to buy the Gforce unit to get it to shift high. I didn't nor did bobby or chase buy the stock trans and have it face plated. What I did was buy then tranny out of the srt 10 viper truck it's strong than the other t56 boxes. The gears are also made from the same strength metal that gforce uses
[/quote]
Im getting mixed reviews on the viper magnum t56. i see you ran one. why are people telling me i cant, what did you need to install it? thanks
tongboy
07-19-2013 11:57 AM
