BRP/SOT Hotside SC Install
Old Apr 25, 2007 | 09:58 AM
  #181
MugenRioS2k's Avatar
Glad to see it
Old Apr 25, 2007 | 10:31 AM
  #182
blackey's Avatar
Message to SOT
Release it as a tuner kit. A lot of the cars are going to run an EMS/Kpro/emanage anyway.
Although nice to have as a complete kit, it's not critical. Besides, when the Greddy turbo kit comes out, you can have a plug and play option anyway.
Bill
Old Apr 25, 2007 | 10:59 AM
  #183
Fyrestrike's Avatar
Originally Posted by blackey,Apr 25 2007, 01:31 PM
Message to SOT
Old Apr 25, 2007 | 11:00 AM
  #184
WLAURENT's Avatar
[QUOTE=MugenRioS2k,Apr 25 2007, 09:58 AM] Glad to see it
Old Apr 25, 2007 | 12:30 PM
  #185
bg03SS's Avatar
tuner kit wolud work for me as I plan on running a AEM EMS.
Old Apr 25, 2007 | 08:45 PM
  #186
Originally Posted by WLAURENT,Apr 25 2007, 01:00 PM
I am really not a fan of piggybacks. The ECU will always try to correct that the piggyback is doing -
Might want to take another look at the ULT.
Only way it would fight the OEM ECU is if you try and tune it at TPSs/loads lower then Open loop.
It controls the injectors and plugs directly it does not modify the input tags like other piggy backs with the exception of the MAP voltage (it has a MAP clamp to prevent the OEM unit from seeing boost.
Old Apr 26, 2007 | 07:10 AM
  #187
WLAURENT's Avatar
How is the timing control of the ULT for the S2000 - the regular emanage is not a very good solution.
Old Apr 26, 2007 | 07:52 AM
  #188
The ULT has a greatly improved timing control over the old Blue.
Not like you would want to advance timing while under boost but the ULT now has the capability to advance timing an retard timing.
Never used the OLD Blue but the ULT ignition timing map is a 16x16 map with user definable rpm points over any range and steps vs Load or TPS
The steps between the cells dont even need to be linear.
Old Apr 26, 2007 | 10:11 AM
  #189
WLAURENT's Avatar
Anyone have a user manual for it?
Old Apr 26, 2007 | 10:22 AM
  #190
try
http://www.mohdparts.com/emanage/ultimate/...onal_Manual.pdf
Be aware of how the pages are laid out "it does not read left to right like you would think" Unless you print it out and staple it in the middle to make it a booklet.
If You need additional specific technical question shoot me a PM and I will give you my contact info. We use a lot of the E-manage ULTs on most lot of cars that come through the shop unless they request a specific brand or want to go full standalone.
