BRP/SOT Hotside SC Install
Old Jun 10, 2008 | 11:12 AM
  #621
slackfaster's Avatar
^^^ looks good
and great to hear the kit holds up under load.
Old Jun 10, 2008 | 12:45 PM
  #622
devs2k's Avatar
Originally Posted by MugenRioS2k,Jun 10 2008, 01:10 PM
Tested the kit out at Talladega Gran Prix Raceway on June 6th
http://www.tgprace.com/
minimum of 20 minute run groups
93 Deg F
Humidity varied 50-60%
The kit performed just as expected.
I did have a fuel issue due to hi G loads
Even with 1/2 of a tank due to the full TEIN Super Racing circuit suspension among other changes to the car the amount of G's the car is capable was starving the fuel pump; time for a fuel cell with a baffled tank.
My previous setup was pushing 1.2G.
Picture of the car in the back straight (approx 90mph at the time of the picture)
what EGTs are you seeing?
Old Jun 10, 2008 | 01:28 PM
  #623
MugenRioS2k's Avatar
820C (1508F) and was for the most part constant (within 10C)
NA I ran in the 850C range after a repeats of long hill pulls at about 32% grade. 1/2 to 3/4 mile long at 100% throttle.
Old Jun 10, 2008 | 04:49 PM
  #624
devs2k's Avatar
Mark, are you using the PLX egt sensor? Where is it mounted (I assume you drilled a bung into your stock or aftermarket header)? How many miles on it? I asked because my second PLX EGT sensor broke and the turbo was only on the car for only 3500 miles!
Old Jun 10, 2008 | 04:54 PM
  #625
blackey's Avatar
Interesting. I see about 1400 post turbo on a turbo kit. What oil temps?
If only it could make 12-14 psi...
Bill
Old Jun 10, 2008 | 04:56 PM
  #626
devs2k's Avatar
Bill
I also 1000-1100 on my greddy turbo (post turbo) moving along on the highway
1200 during a spirited drive
1400 balls to the wall
Old Jun 10, 2008 | 06:02 PM
  #627
GRUNTS2K's Avatar
Farenheit right?
Old Jun 10, 2008 | 06:24 PM
  #628
devs2k's Avatar
Originally Posted by GRUNTS2K,Jun 10 2008, 10:02 PM
Farenheit right?
yes
Old Jun 10, 2008 | 08:01 PM
  #629
DEFI EGT probe
Located about 1" from the final merge collecter on the header.
This gives an average temp across all 4 cylinders.
Header is wrapped extensively with 2 layers of Thermotech.
My EGTs are slightly higher since A/F are in the 12.1 area instead of 11.5-11.8 (typical turbo) and even richer for the Greddy turbo. So EGTs form those turbo kits to this setup in not entirely apples to apples.
Need to re look at the in car telemetry/data logs to get the Oil/Water temps.
Its at the shop So I will look tomorrow and let you know.
Note I am only running 1.5 deg of retard at 6.5 psi since Intake temps are only about 10-15 deg F above ambient due to such an efficient intercooler.
This is a little bit more aggressive timing then will be included in the base line tune despite not having any problems with it at -1.5 deg.
Old Jun 11, 2008 | 04:21 AM
  #630
devs2k's Avatar
[QUOTE=MugenRioS2k,Jun 11 2008, 12:01 AM] DEFI EGT probe
