Cam Timing with Supercharger
Old Dec 19, 2011 | 04:42 PM
  #131
S2SEXY's Avatar
close up of a cam gear.so if you spin the center section to the left it will put that scale in advance.
Old Dec 19, 2011 | 04:44 PM
  #132
watch0bak's Avatar
Originally Posted by S2SEXY
are we sure its correct?if they move counter clockwise then more to the left should be advance,but if you move the intake to the left and the exhaust to the right you would increase overlap.ahhhh crap
So are you suggesting that the drawing is possibly wrong and that installing them according to the drawing will make it increase overlap?
Lets get this straightened out so we can install it right on Thursday!
We have confirmed to do the run on Thursday! I'd like to work out this confusion before I head over to DO!
- Sung
EDIT: so I think I read over this more than 20 time. Each time I read it, it makes sense, and then I see a different way. I am totally confused now.
I have dug up this response from sideways:
Your questions: I think the exhaust cam rotates clockwise, correct? So advancing it two degrees makes it a little further in a clockwise direction at TDC than it would be stock?
Not correct.
From the front of the engine, both cams turn counter clockwise.
The cam should move counter clockwise in relation to the sprocket to advance and clockwise to retard.
The cam timing will look stock with the key advancing or retarding the cam 2 degrees in relation to the sprocket.
If this statement is correct, the picture SHOULD be wrong. I will wait for more people to contribute on this
Old Dec 19, 2011 | 05:08 PM
  #133
Thunder-rush's Avatar
Heres a link on cam timing from turbo magazine.
http://www.turbomagazine.com/tech/tu...s/viewall.html
Old Dec 19, 2011 | 05:11 PM
  #134
watch0bak's Avatar
Originally Posted by Thunder-rush
Put both marks even and work the exh cam first. Put the key in if the mark goes backward then you retarded it if it goes forward then is contrary. Les overlapping means the exh cam retarded a bit. It is supposed to shift the powerband to the left in the graph and increase power lower in the range. More overlap on NA does contrary les power down low more up top.
please specify what backwards and forwards are. I think we should start using clock-wise and counter clock-wise as to cause no more confusion in this matter!
- Sung
Old Dec 19, 2011 | 07:54 PM
  #135
Sideways's Avatar
See how the red section turns inside the black section to change the cam timing.
The cam key does the same thing in a fixed amount.
The red part is fixed to the cam. See the scale at the top of the red section.
A slight movement of the cam counterclockwise while holding the black section of the sprocket fixed will give cam advance. Note the little A on the scale.
The opposite direction is retarding the cam timing. Since your shop guy is following this thread ask him if he understands clearly.
Old Dec 19, 2011 | 08:08 PM
  #136
RAIN H8R's Avatar
right on Sideways!
Old Dec 19, 2011 | 08:13 PM
  #137
watch0bak's Avatar
If that is the case, the picture is wrong, correct?
Looking at this picture again,
putting the keys on the exhaust side in such a way will make the cams go clockwise, thus retarding exhaust side. In same principle, the key on the intake side will make the cam gear turn counter-clockwise, advancing the exhaust.
So basically, the diagram that has been drawn and agreed upon is wrong? Let me know if you are following it.
- Sung
Old Dec 19, 2011 | 08:34 PM
  #138
RAIN H8R's Avatar
my diagrams are correct
Old Dec 19, 2011 | 09:09 PM
  #139
watch0bak's Avatar
Damn.. okay.. looked at the forum again.
Offset moves the cam in relation to the cam gear. The lower part of the key is the offset. In the diagram above on the exhaust the lower part is offset to the left thus advancing the exhaust cam. On the intake side the lower part of the key is offset to the right thus retarding the cam. Both cams turn left (counterclockwise.)
The drawing and the orientation of the keys is correct.
The degree number imprint is on the left side of the key when advancing and on the right when you want to retard.
And then I looked at the keys. The drawing matches how the keys are supposed to go. I thought the top part of the key is the offset. Misunderstanding on my part.
So, JUST in case they stopped following this thread, I will be taking these photos in:
In addition, I will probably give them a call tomorrow and email them the 2nd picture, making sure they understand and agree.
Any1 see any corrections I should make?
- Sung
Old Dec 20, 2011 | 02:47 AM
  #140
RAIN H8R's Avatar
looks good to me. So now that w have everything confirmed as what it should be, are you certain you had them installed correctly the first time?
