Cam Timing with Supercharger
Originally Posted by RAIN H8R' timestamp='1324295458' post='21247456
[quote name='Sideways' timestamp='1324292148' post='21247413']Well, I asked and was told the ignition timing is totally independent of the cam timing. Does DO have experience with S2000s other than yours?RAIN H8R, the only way to tell if yours are in correctly is to look. Did you loose torque? That diagram is correct.
Current recommendation is retard the intake one or two degrees and advance the exhaust one or two degrees to make 3 degrees less overlap.
[/quote]
That makes sense with the drawing now. To me either way you look at the offset tab on top or bottom it was the same orientation. So if the original poster had the keys like the diagram that seems to me -2 +1.
More information to follow soon. It looks like the appointment will be set on the Thursday! Apparently DO has been following this thread also. The owner said that he will send me an email tonight sometime with all the information so I will be relaying the message shortly!
- Sung
- Sung
- Sung
- Sung
