Cam Timing with Supercharger
Old Dec 28, 2011 | 12:26 PM
  #221
watch0bak's Avatar
Originally Posted by s2000Junky
Originally Posted by Sideways' timestamp='1325090160' post='21268348
It appears cars with restrictive exhausts (like factory) should run just 3 degrees advance on the exhaust and leave the intake stock.
That leaves the overlap at three degrees less and helps the exhaust to clear.
I saw big improvements with 0 intake, +3 exhaust cam settings. My exhaust is very free flowing so the cam timing was not ideal.
I'm looking for someone with a restrictive exhaust to dyno test the 3 degree exhaust advance.
I would like to post the before and after dyno charts for all to see.
Please let me know if you are interested and we can discuss.
I'm thinking a factory setup with 7-8 psi should see about 10 horsepower.
I would probably be a good candidate for this being I have a maxed out 14/15psi Novi1000 on a stock f22 with factory header and stock size 60mm TP/dual cat back. I have done some dynos at the same place Watchobak did, but not at my current psi level. Waiting for my blower to get back from rebuild yet before I can tune and move forward with anything.
Haha, this fits me pretty well too! I do have stock exhaust and t1r resonated TP but I will let other people do some more testing! It'd be interesting to see what +3exhaust and 0intake does. I think I am fairly satisfied with my results for now!
s2000junky! do it!! maybe I can come watch ^^
- Sung
Old Dec 28, 2011 | 12:28 PM
  #222
Moddiction's Avatar
Former Sponsor
I'll be testing these sometime over the winter. Already checked and can have them installed while on the dyno at my tuner to see the gains.
Sideways. I have a 70mm se dual exhaust with 70mm test pipe and stock header. Would the combo that was dyno'd be the best combo still you think?
Old Dec 29, 2011 | 04:13 PM
  #223
S2SEXY's Avatar
sideways i got my keys today,thanks for the fast shipping.they look as if they will not make any difference since they have almost no difference in the lips.
Old Dec 29, 2011 | 04:46 PM
  #224
s2000Junky's Avatar
There isn't going to be much of a step in the key when your only moving 1-3 degrees. Think how much your actually moving the overall diameter of the cam sprocket which is about 4" away from the inner shaft where the key is. There is much more moment at the outside of the cam sprocket then the inner where the key is. Half a mm at the key probably moves the outside of the sprocket close to 3mm.
Old Dec 30, 2011 | 08:25 AM
  #225
Sideways's Avatar
Originally Posted by Moddiction
I'll be testing these sometime over the winter. Already checked and can have them installed while on the dyno at my tuner to see the gains. Sideways. I have a 70mm se dual exhaust with 70mm test pipe and stock header. Would the combo that was dyno'd be the best combo still you think?
Just the same, -1 intake, +2 exhaust.
It is exciting to get a big increase in power from a little tweek.
Old Jan 1, 2012 | 10:38 AM
  #226
Road racer's Avatar
Sideways,
Thanks for sending the keys out so fast. I am planning to install them this afternoon.
I looked at ther Service Manual and found torque specs & tightnening sequence for the cam holders. The manual says that I need to loosen all of the rocker adjusting arm screws prior to removing the cams. Is loosening the rocker adjusting arm screws step required (or suggested)?
Would you expect any changes to valve clearance since the lobe centers are now offset? I wouldn't think valve clearances would change that much if any due to only 1-2 deg of rotation.
Anything else I need to be aware of?
Thanks!
Chris
Old Jan 1, 2012 | 12:42 PM
  #227
Sideways's Avatar
Originally Posted by Road racer
Sideways,Thanks for sending the keys out so fast. I am planning to install them this afternoon. I looked at ther Service Manual and found torque specs & tightnening sequence for the cam holders. The manual says that I need to loosen all of the rocker adjusting arm screws prior to removing the cams. Is loosening the rocker adjusting arm screws step required (or suggested)? Would you expect any changes to valve clearance since the lobe centers are now offset? I wouldn't think valve clearances would change that much if any due to only 1-2 deg of rotation. Anything else I need to be aware of? Thanks!Chris
Some with hands on experience may reply here, I use a mechanic.
Failure to do this correctly can lead to broken cam caps.
Changing the cam timing will not impact valve clearance in the normal sense.
It can decrease the valve to valve clearance but that is not an issue here when going the directions we are going.
Old Jan 1, 2012 | 08:08 PM
  #228
Road racer's Avatar
I just finished installing the keys. No problems at all.
I went ahead and loosened the rocker adjustment arm screws on the cylinders #2 & #4 exhaust valves and the #3 and #4 intake valaves as they appeared to have some valve spring tension (due to position of cam lobes while at TDC). After the keys were installed, I reset/rechecked all the valve clearances (.008 intake & .010 exhaust). You could probably do it without loosening the rockers but I did not want to risk damage to the cam towers.
Now ready to get it retuned (Feb 8th! )!
Old Jan 2, 2012 | 11:06 AM
  #229
joes sled 2000's Avatar
So i imagine that when these keys are added that you will need to recalibrate the ignition timing ?
Old Jan 3, 2012 | 02:28 AM
  #230
s2konroids's Avatar
Think you probably will imo.
