Cam Timing with Supercharger
However the results are disappointing, its as if the car has only responded ever so slightly to the keys about 8-9 BHP @FLY up top (on further inspection i initially thought it was 12BHP) and about 2 lb/ft in places - these are the figures at the fly BTW.
Comptech supercharged with aftercooler @ just under 10psi
Thanks
Thanks
LG
Hi,
So i installed the keys the other day piece of cake really and no where as difficult as i thought
I specifically followed the instructions and got someone else to validate esp the numbers facing etc.
My specs are
63 testpipe
63 5zigen singlepipe exhaust
tracysports header
+2 on the exhaust, -1 on the intake.
Thanks
My specs are
63 testpipe
tracysports header
Thanks
Every engine is a little different and thus results will vary.
Anything you do to add power now will add a little more because of the cam timing change.
Little things like more boost, bigger exhaust, better fuel.
How much tuning was done on the dyno? Was fuel added? Was the tuner being safe? Is there a plot to share?
I don't have an overlay with me at this moment in time.
It looks like there were no any gains until after 7600rpm even then it was around 2BHP, up top at around peak is where i noticed small gains, even then it may have just been due to the fact it leaned the mixture out a little (from 11.7 to 12.1 AFR) so the cam timing 'could' have done nothing. The belt was slipping slightly at the top end at the power was originally down from when i was last at the dyno, it was tightened and power shot up.
I did advance/retard the timing slightly with no gains in power so the timing was pretty much spot on with the cam keys and before. I am the tuner.
I'm not sure what went wrong really.
The fact that it made the afr leaner shows that the engine is breathing better as a result. I think it’s safe to say that if you were maximizing the pressure from your blower, that you probably would see your current gains two fold.
At my level I’m really interested to see what gains I would make. I'm making nearly 16psi at only 8k rpm. After all my efforts getting my car back on the road and running good, I am leery of performing this operation though, as strait forward as it is. I dont like the idea of undoing the head bolts. hg failure scares me a bit running my pressure level and injecting water/meth.
AJ did you see any difference in boost pressure measured after this? More? less?
Please explain...
Please explain...
