Centrifugal Superchargers, not enough torque?
Old Nov 14, 2009 | 08:59 PM
  #31
s2k aok's Avatar
low boost sc + 4.77s = awesome
an old used comptech non-ac and gears is cheaper than getting a whalepenis intake, jdm header, testpipe, and jdm exhaust...
Old Nov 15, 2009 | 07:20 AM
  #32
Excalibur's Avatar
I'm a newb and was wondering what all people are using to tune the car after sc?
Old Nov 15, 2009 | 08:32 PM
  #33
Moddiction's Avatar
Former Sponsor
Yeah that's what I will be having shortly! Can't wait. I am sure I will be boost happy though and have to ditch the 4.77's after a little while to get stock or not quite as short gearing in it again.
Old Nov 16, 2009 | 08:46 AM
  #34
s2000 x's Avatar
While I love turbos and love the extra torque they provide there is a lot more to deal with concerning maintenance, heat and upgrades. I had a 350hp 95 dodge neon that was running 12.2's all day long at English Town and believe it was fun as hell.
The problem with the s2000 is the stock drive train does not take well to all the extra torque from a 350+ turbo setup. People end up reinforcing their diff or just purchasing pudy's diff kit or inline's kit which cost $$$. Plus you have to deal with added heat which will require you to most likely relocate items in the engine bay such as the fuse box etc.
With the supercharger heat is really not that much of an issue plus you can reach higher hp without completing redoing the car and if you are doing that you are probably better off buying a better platform to reach high hp gains for less time and money.
The whole reason I am going for a 400hp vortech setup on my s2k & not go turbo is because it allows the car to keep stock around town, less maintenance (spend more time having fun then downtime) & all I need is a stage 2 clutch since I don't plan on launching the car or driving like a lunatic on crack. Will most likely lower the vtec setting down to even out the power band which will help in when the blower kicks on.
Also I will be doing this on a stock head gasket which has been known to go up to 500 safely. If it ain’t broke don’t fix it is seems to come to mind. Just to give you idea on mods as well this is what I will have:
SOS Throttle Body – More air flow
DC Headers – less bends that stock and ceramic will help in airflow and IAT’s
63mm Berk Highflow Cat – 80% more airflow and no test pipe smell
Fujistu Legalis Exhaust – 63mm which will help is more airlow than stock & sound
SOS front mount aftercooler – Bring in more air and tame heat soak
Plus the usually stuff. My goal is 400bhp on the least amount of boost.
It really comes down to what type of goals you have and what you want from the car horsepower and drivability wise. Good luck.
Mike
Old Nov 16, 2009 | 11:26 AM
  #35
vader1's Avatar
Originally Posted by Enthralled,Jan 19 2007, 08:51 PM
I think he's looking for something with some power down low.
ROOTS!!!!!!
Still a very happy SOT kit owner. Now that I have my VTEC point fixed (my fault, had a wrong jumper position) its 200 ft lbs of torque instantly, and it easily shoves enough air to lower VTEC to 4000 rpm. Makes for a nice powerband and you can break the tires loose easily in first or second without much effort.
Around town in traffic, its a totally different beast and zips around in traffic without effort the way an NA S2000 never could. The SC whine grows on you too.
Not that SOS, Vortech, or Kraftwerks are bad kits, they just don't put out low end the way the roots does. The SOT kit is a little more than the current centerfugal kits, but if you have to add gears, then its less.
Old Nov 16, 2009 | 02:34 PM
  #36
s2000Junky's Avatar
Originally Posted by purehonda,Jan 19 2007, 09:13 AM
The peak power output only occurs near redline because boosts slowly builds with RPM increase. So torque isn't there until very high up in the RPM range.
I'm thinking an upgrade should help improve the weak points of a car not just pass it on with a bit more top end HP.
I guess most SC owners want more redline horse power. I think for a broad and solid HP band improvement... turbo is the only way to go.
Correct me if I'm wrong.
Its true, it is two totally different power curves. Turbo simulates more of a v8 which some like and SC keeps more with the power band of an inline 4 such as a bike. Your trq and hp will depend on how much boost you run. I suppose there is an instance where a high boost SC would have a fatter power curve overall then a more conservative turbo, so keep that element in mind. A given trq curve only works if you can get it to the ground as well. The nice thing about SC is that it is more tractable and forgiving lower in the rpm range for the track or street, its predictable or more drivable, yet has the explosive power output in the upper rpms where you expect the car to perform. I'm not going to get into any other elements of pros and cons of each, just the performance differences. Maybe this gives you some more to think about.
vader1
Jul 15, 2008 05:44 AM
Trigun
Jun 29, 2006 06:24 PM
rai
Nov 3, 2005 10:58 AM
TTSUPRA
Jul 19, 2002 02:07 PM
BnB-S2K
Jul 9, 2002 01:05 AM
