Clutch recommendations
Old Jan 25, 2010 | 09:21 AM
  #21
B5254T4's Avatar
Do you know if S2000 use 240 mm disc? I´ve used Sachs Race plate on most of my cars with 240 mm disc.
Old Jan 25, 2010 | 09:38 AM
  #22
D1sclaimer's Avatar
Originally Posted by CosmosMpower,Jan 25 2010, 11:49 AM
What's the difference between the old and new versions, how can you tell by loooking if it's the new one?
I think all it is, is less clamping force. I was reading something where it could cause crank walk by having too much clamping force.
Old Jan 25, 2010 | 11:30 AM
  #23
gt30r's Avatar
I run this same Spec clutch in my Evo, very streetable
http://thmotorsports.com/spec_clutch/spec_...h/i-170698.aspx
Old Jan 25, 2010 | 12:08 PM
  #24
NorCal F20's Avatar
Originally Posted by xeuxx,Jan 25 2010, 09:27 AM
https://www.s2ki.com/forums/index.php?showtopic=731097
Are you really going to DD 500WHP?
Maybe consider the SOS Sport Clutch......
The SOS sport clutch is only rated up to 255 lb/ft to the wheels im sure if he is at 450+ whp he will b over 255 in wheel torque
Old Jan 25, 2010 | 12:51 PM
  #25
m R g S r's Avatar
Don't hold me to it, but I believe the clamping force is very close to the same, but with the redesign they were able to lesses the lateral force exerted on the crank, which helps to avoid trust bearing (or washer, whatever you want to call them) damage.
Old Jan 25, 2010 | 02:14 PM
  #26
skem's Avatar
Originally Posted by TRBOKEV,Jan 24 2010, 08:26 PM
I have the cc stage 4 six puck sprung and it is an f'n beyach to drive...
I'm thinking of going with something new already after 5k miles..
I'm tired of looking like a tard with this clutch...
How is the SOS twin as a DD clutch? Is it on off like the puck clutches?
you should get used to it, especially once it breaks in which it should have already. after installing a 3" catless exhaust it relieved a lot of back pressure and made it even easier and more fun to drive, i was downshifting smoothly like nothing.
Old Jan 25, 2010 | 02:26 PM
  #27
s2000 or 240sx's Avatar
I have a 6 puck sprung stage 4 comp clutch and it is ok to drive but just a pain in traffic or on a hill. i too look like a tard sometimes driving it but it is a badass setup
Old Jan 25, 2010 | 02:27 PM
  #28
SpaS2K2005's Avatar
So where do we start looking cuz im in the same department right now. I'm turboing very soon and I'll be between 450 and 500 whp and upwards of 300 wtq and I'm looking for a clutch also.
Old Jan 25, 2010 | 02:57 PM
  #29
EternalLx's Avatar
The ACT pressure plate with either the OEM disk or the ACT disk will hold 450whp. 500whp and over I recommend the ACT disk.
The SOS street clutch wont hold 420whp+
Old Jan 25, 2010 | 04:35 PM
  #30
SpaS2K2005's Avatar
So which act clutch kit are we talking about? I'm going to order a clutch this week and want to start looking for better prices. I just don't want to pay a ton for a clutch that isn't going to hold the power I'm looking for.
