clutch replacement
Old Oct 29, 2007 | 08:08 PM
nMeOnE's Avatar
Default clutch replacement
I'm probably sure many of you guys are tired of my noobish question, but i just wanna make sure b4 i slap this turbo on aka moneypitt!
Well i'm replacing the clutch with the act street clutch package which includes HD pressure plate and oem street disc. I was wondering if i could just use the original flywheel or do i need to get a new one? Also if i were to use the original one do i need to have it resurfaced?
regards,
Tom
Old Oct 29, 2007 | 08:39 PM
LostMotion's Avatar
Yes
Old Oct 29, 2007 | 09:29 PM
nMeOnE's Avatar
what are you talking about? people resurface flywheel b/c there is friction between the clutch and flywheel when engaged which creates friction on the flywheel that causes it to warp/crack overtime due to heat fatigue.
Old Oct 30, 2007 | 06:58 PM
ChefJ's Avatar
Yes have it resurfaced. You are going to be FI now and the AP1 flywheel is just fine for your application.
Old Oct 31, 2007 | 03:53 AM
SWIFT2000's Avatar
that is the exact set up i use and i love it. It feels almost like stock but grabs so much better. My clutch was never slipping so all i did was resurface the flywheel and its fine.
Old Oct 31, 2007 | 08:01 AM
S2KB00ST's Avatar
You will most likely need to resurface the flywheel..
pbook4g5
Mar 15, 2016 05:08 PM
s2steve
Jan 15, 2008 08:50 AM
Boostedtaco
Jun 15, 2007 08:27 AM
s4000k racing
May 29, 2007 05:31 PM
cjb80
Jun 9, 2004 09:23 AM
