Creating A Monster S2K
Guys are super knowledgeable, friendly, and will help you in any way.
I'm sure I've called them with a couple of face palm questions but they have always helped steer me in the right direction.
Point taken about the wide bodykit.
What kind of aftermarket fenders are available for me to purchase if I decide to keep the body relatively stock?
I will want the widest possible rear and front tires with this kind of power. I won't be running drag tires as I don't plan on regularly dragging my S2K, it will be a street machine.
just run some over fenders in the rear if u want a lot of rubber back there, i run 275 nt 01s in the rear at around 800hp and they hold well, boost limited in the lower gears though
From my own experience I would think $50.000 would be a conservative estimate.A large rear wing will only benefit at high speed,you would be better off smoothing the underneath of the car,that way you will retain the stock look and not attract too much attention.
That kind of power isn't just a case of bolting a big turbo on,absolutely everything has to be modified or uprated.
With my own car I have completely replaced the Brakes,all the suspension apart from the lower wishbones,the complete fuel system apart from the tank,the whole engine,trans,clutch,diff,driveshafts,even down to the wheel studs.The cooling system has been changed and I would say a vented bonnet is a must.
You have PM.
You have PM.
