CTSC w/ 9psi or 10psi pulley question...
Old Nov 6, 2006 | 08:24 PM
j66's Avatar
j66
Default CTSC w/ 9psi or 10psi pulley question...
i'm finally planning to not go 7psi and go the 9psi or 10psi route, what side of injectors do i need to run this setup, and i have emange (not ultimate) already, i wonder with emange tuning the Air/Fuel and timing will work or is there other stuff that's needed with AEM EMS to tune the car? hope you can direct me to the one path. thank you =)
Old Nov 6, 2006 | 08:31 PM
elusiv's Avatar
With emanage blue, i think you're limited to 550's either way. with 10psi, you may wanna think about 750's and EMS.
Old Nov 6, 2006 | 09:52 PM
Nugget's Avatar
750 seems a little large for 10psi. I would think 550 should suit you fine. I personally am not running that. Hopefully someone that is will chime in.
good luck
Old Nov 6, 2006 | 10:21 PM
batikan's Avatar
I am running 11.5 psi with 750cc injectors but it is more than enough. With 10psi, you should be at 345 whp and my friend uses 675cc's with his 410whp s2000. 550cc will be enough for you.
If you need map sensor and the map sensor harness for cheap, pm me I have used one for sale...
As for the Engine Management, AEM is always the better option but eManage will work too...
Old Nov 6, 2006 | 10:23 PM
batikan's Avatar
ohhh you have comptech kit. sorry, didn't see it. with comptech @10 psi you'll be at 350+ whp and you may want to consider 650's...
Old Nov 7, 2006 | 02:24 AM
QUICK_AG's Avatar
You will be fine with 675's and AEM is a must. I am currently running 675's with a 3.5" pulley or 9lb. and have plenty of injector left (I am also running aem ems). Good luck and have fun
Old Nov 7, 2006 | 07:16 AM
OyATL's Avatar
[QUOTE=Nugget,Nov 7 2006, 01:52 AM]750 seems a little large for 10psi.
Old Nov 7, 2006 | 07:19 AM
Dsgs2k3's Avatar
550 are defiantly more that enough.
RISLAR
Mar 29, 2008 11:57 AM
S_NeWb
Apr 16, 2007 06:29 AM
gusrock77
Aug 9, 2006 12:52 PM
SC-S2000
Feb 20, 2006 10:02 PM
e12ic
Jan 12, 2006 08:16 AM
