DBW + Flashpro. What multi gauge are you guys using?
Old Dec 2, 2012 | 06:34 AM
jdmdohcpower's Avatar
Default DBW + Flashpro. What multi gauge are you guys using?
I have an AP1 now with EMS and serial gauge. Im thinking about getting an 07 and do the same build but use Flashpro. My question is what multi gauge are you guys running? I know there are some that have to have a box for each sensor.. Just looking for the best solution. Looking to run PSI, oil pressure, AIT, Wideband A/F.
Is there anything that will talk to the MAP sensor like EMS? or do you have to install sensores for everything?
Old Dec 3, 2012 | 03:31 PM
Anyone??
Old Dec 3, 2012 | 11:57 PM
Manny2587's Avatar
I use the plx dm-6 multi gauge. You have to buy each sensor module separate which comes with the control box and sensor. Then you just link all the sensor modules together using the supplied wiring. The modules arnt very big and pretty easy to hide under the dash. The gauge itself is very slim and I had no trouble retrofitting it above the start button.
Old Dec 4, 2012 | 01:00 AM
Picturepro's Avatar
I started a thread about gauges and where to place...
https://www.s2ki.com/s2000/topic/989...ler-gauge-pod/
Old Dec 4, 2012 | 12:41 PM
Thats pretty much what I gathered from my reasearch. Where exactly did you mount the boxes behind the dash?
Gauge placement is no problem. I like the A pillar
Old Dec 4, 2012 | 03:14 PM
S2K-F8's Avatar
I'm running a DM-100 an DM-6 (both flush mounted). The box for the DM-100 is mounted just under the start button behind the dash. I'm running 3 sensors to the DM-6 (so 3 boxes). I mounted them behind the panel where the glovebox would normally be.
Scott-
Old Dec 4, 2012 | 09:21 PM
s2guru's Avatar
PLX is the best, i have the 60mm one ( i wish i had the 52mm so i can flush mounted )
Wydget
Apr 10, 2012 06:52 PM
edomund
Jul 31, 2009 06:19 PM
icemans2k02
Jun 27, 2006 08:09 PM
darkfx
Apr 29, 2006 05:52 AM
