Engine load and VTEC
Old Dec 1, 2015 | 06:52 AM
jcunningham's Avatar
Default Engine load and VTEC
Hey guys,
So, I'm new to SC, and have a basic question.
On an AEM v2 EMS, it appears that you set the VTEC engagement based on 3 factors.
Throttle position
RPM
Engine Load
I know Engine Load is sort of a loosely defined term, but, I believe in our engines, it's based on the MAP sensor, correct?
And if so, lets say it's set to come on only above 5 PSIg, does that 5 psi essentially mean 5 psi of boost, or am I simplifying it or confused?
Old Dec 1, 2015 | 06:56 AM
baZurk's Avatar
Yes, engine load is measured by the map sensor. However, you have two units of measurement mixed together. Either use PSI or mmHg. You can google a conversion calculator to compare the two.
Old Dec 1, 2015 | 07:36 AM
Thanks.
The units in the AEM table though are PSIg. You can choose to display it in various units, but that's what it is now.
Old Dec 1, 2015 | 08:48 AM
baZurk's Avatar
Originally Posted by jcunningham
Thanks.
oh sorry about that. The "g" just means that your pressure reading is relative to atmospheric pressure. So your 0 load is actually positive 14.7 at sea level.
Old Dec 1, 2015 | 08:52 PM
Originally Posted by jcunningham' timestamp='1448987808' post='23816732
[quote name='baZurk' timestamp='1448985407' post='23816701']
Thanks.
[/quote]
Ahh...ok, thanks.
So, if it was set to say 5.0 PSIg, that essentially means 5 lbs of boost (at sea level)?
RZA
Aug 4, 2015 07:23 AM
s2000gt35
Sep 26, 2013 06:44 PM
durtbikedude365
Dec 1, 2010 11:21 AM
indebt&lovinit
Sep 3, 2007 03:23 PM
John MI blk/blk '01
Mar 31, 2002 06:08 AM
