f20c 106mm x 89mm turbo project
Old May 15, 2013 | 09:52 AM
S2Thaga's Avatar
Default f20c 106mm x 89mm turbo project
What are you guys ideas on this project? I will be putting a list of everything down.
Old May 15, 2013 | 10:22 AM
devildust's Avatar
There is an FI section and you might want to give more detail. Post like this will get you nowhere.
Old May 15, 2013 | 11:06 AM
JUSTINTHECOASTIE's Avatar
The 106mm stroker kit itself makes good power, adding boost is going to magnify that power. Do it. Only worry would be side load on pistons, which probably won't matter if you use lnlinepro's kit
Old May 15, 2013 | 06:50 PM
S2Thaga's Avatar
the only problem is I see that it it so little space between the piston that trying to o ring the head is going to be a problem, also im worried about the HG not sealing.
so far i have a f20c block resleeved to 89mm, head has a inlinepro full race port, ferrea 1+ comp plus valves, CATSCAM stage 3, toda dual valve springs,
block wise is inlinepro 106mm billet crank, carrilo pro h beam rods, and JE 89mm pistons.
Old May 15, 2013 | 07:01 PM
Head gasket is not an issue, the other thing you stated, I don't understand what you're describing
youngkilla
Jun 8, 2014 07:43 PM
bois2k
Aug 30, 2010 10:40 AM
bois2k
Jul 12, 2010 09:16 AM
tugsta
Nov 7, 2009 06:10 AM
passmans2kny
Dec 22, 2005 11:08 AM
