f24 turbo
f24 turbo
Hello! I have s2000 with 2,4 stroker kit and i have a turbokit on it now with str cast iron exhaust manlfold ,garrett t3/t4 turbo(450hk) 2,5 inch exhaustsystem id 1000 injectors 2inch intercooler piping ! I nog got it tuned at 10psi and got 305whp and 360nm and tas a Little disopointed of numbers ! The Tuner dident know much ignition to use ! So i wunder does anyone her know how much is safe on a f24 ! Some kind of guide Lines? Im from Sweden so my speeling aint that god:-)
Your hardware is also holding you back tremendously. In addition to your cast manifold, the 2.5" exhaust is not enough for the 2.4L engine, and your 2" intercooler piping is also restrictive. Keep in mind that your larger displacement engine needs to be able to move more air in and away from the engine so replacing those parts before seeing a new tuner will definitely put that e85 to use. What AR is the turbine housing on your turbo?
Its kind of small 0,63 i wont go and change my setup ! My goal was 400hk in the engine and i got 350hk and 360nm now! Its 310nm at the wheels not 360nm that i wrote at first
.63 is definitely too small for a 2.4l. I know it's probably not what you want to hear, but your setup is the biggest thing holding you back right now. Sure, you could probably do a little better with a new tune, but to really utilize the larger displacement, you should look into upgrading to at minimum, a larger IC and exhaust setup, and turbine housing.
I culd get 3 inch catback but i got no room for a 3inch downpipe But if Do this and the intercooler piping and have the 2,5inch downpipe Do you think 400hk i possible ? Or Will the engine get damage becuse the Turbine housing is so small? What wulde be a god choice for the turbine ?
Mino8123
03-16-2012 05:09 PM
