Finally Done with Full Race Turbo Kit! UPDATED!
Originally Posted by spdracerut,Apr 24 2009, 06:04 PM
Very nice setup.
What are you running for the clutch and rear diff?
I forgot I left that out:
ACT Heavy Duty Pressure Plate
ACT Street Disk (load capacity 383lbs- uh oh)
Competition Flywheel 11.5lbs
OEM Diff/Gears
Originally Posted by AndyFloyd,Apr 23 2009, 05:30 PM
To the person that asked why your power curve looks the way it does....bisi it seems doesnt really lower the vtec much and it appears thats why you spike so hard right around 5500-6000 when the motor comes on the big cam. You should lower vtec if its not to like 4k because the full race manifold wants vtec lower, it will give a LOT more midrange. I use a log with that same turbo and make less peak torque but drop off a lot less as well. You are pushing that compressor and turbine wheel to their maximum with the #'s your getting so its normal for torque to drop some.
In contrast, a few days ago he tuned a supercharged S2000 where the vtec engagement was at 4100 because that's what worked best for his setup.
Either way, both he and his wife Hedi has invited me back to alleviate any rumors of him not knowing where to put the vtec engagement. If for some reason lowering it works better, he's not too proud and would be the first to admit it, learn from it and become a better tuner because of it. And If not, he's already a better tuner just for trying (IMO).
I need to go back to get a psi/speed tune for traction anywyas
Again, I stand 100% behind my tuner and the tune he gives me.I also welcome any comments and suggestions with my setup. Thanks for looking!
Originally Posted by AndyFloyd,Apr 25 2009, 09:25 AM
My clutch has slipped one time and im making 370-380 ft/lb. It did it once and this was after tons of pulls on the dyno, has been fine since....
edit : i have the same ACT as you.
How many miles do you have on it?
Originally Posted by jirro22,Apr 25 2009, 09:28 AM
paul ur car is sick fast...excellent job on the detail on how u dress ur engine bay...its an inspiration.
Originally Posted by passmans2kny,Apr 25 2009, 12:25 PM
sick man, awesome everything came together so perfect, u have the best heat shielding on a full race kit i have ever seen, the shield on the turbo is like art
I copied your oil filter location too. The original location is only good if you have a filter that has elements you can replace because it screws out from the bottom of the filter. I made a mess when changing out the break in oil.
The swaintech does not chip off, but it's still waaay too hot! I still melted my polyurethane motor mount! The heat shield really helps. its a good long term investment IMO!
