FMICand SC install thread, FINALLY TUNED and done
Old Jan 31, 2008 | 06:27 PM
  #71
lkingcuongl's Avatar
I have the kit, and I have a really nasty U bend because we did not clock the supercharger. I am only yielding a loss of 1psi on a 9lb pulley.
Old Jan 31, 2008 | 06:55 PM
  #72
WindchaserS2K's Avatar
But yours install and the U-Bend look way different than the one on UR website
Old Jan 31, 2008 | 07:39 PM
  #73
Like I stated above, the supercharger was not clocked like shown on UR's website. I was implying that maybe the results would have been better if they were done to spec.
Old Jan 31, 2008 | 07:47 PM
  #74
shavedturbo's Avatar
none of the pics work
Old Feb 1, 2008 | 06:30 PM
  #75
S2K_GP's Avatar
[QUOTE=nightcrawler7188,Jan 31 2008, 01:48 PM]with regard to the FMIC thing--the insides of the piping had precipitation from the welds, so it was not 100% smooth.
Old Feb 1, 2008 | 06:34 PM
  #76
Envied's Avatar
I work at an exhaust systems factory that manufactures units for new cars using stainless steele. We use generally fabcor 409 wire and some other wires depending on application.. We use 98/2 argon and DONT backpurge. Everything is leak tested using Cosmo leak testers.
Old Feb 1, 2008 | 06:42 PM
  #77
S2K_GP's Avatar
Are we still talking about TIG welding here?
Old Feb 1, 2008 | 09:05 PM
  #78
Envied's Avatar
Ah you got me! But we do SOME tig welding for bushing and what not that is not back purged and no propblems.
Old Feb 2, 2008 | 04:51 AM
  #79
nightcrawler7188's Avatar
Originally Posted by S2K_GP,Feb 1 2008, 11:30 PM
This is probably the main, if not sole cause, of your large pressure loss. Stainless steel needs to be back-purged from the inside with Argon. If this is not done you will see crystallization deposits all along with inside of the tube where the weld occurred. I'm pretty sure that if you were to cut the "JDM" section of the intercooler pipe along its length, the inside would probably resemble a corrugated drain hose. Mild steel with a powdercoated final finish may have been a better choice since it does not need to be back-purged. Aluminum, however, would have been the best way to go. Its a lot lighter, though it is more difficult to weld. I'm glad to hear that you were eventually able to get your car tuned though. Welcome to the FI club.
thanks for the advice and the welcome. we knew we could have backpurged to get rid of the crystallization on the insides but we decided to give it a shot and hope for the best. i hope to upgrade to the UR kit once summer starts.
JUSTINTHECOASTIE
Florida For Sale
Jan 11, 2019 05:29 AM
turbo8765
Feb 23, 2013 06:32 AM
Kinnersly
Feb 22, 2010 01:36 PM
kylemonster85
Sep 27, 2008 09:06 PM
batikan
Mar 14, 2006 07:02 AM
