Fuel Damper Screw Loose
Old 12-12-2012, 10:53 AM
chris2k03's Avatar
Default Fuel Damper Screw Loose
My car started dying intermittently not too long ago. I thought it was a tune issue since I recently had the motor rebuilt (oem specs), so I got it re-tuned. The problem remained, so I've been trying to diagnose it for the past week.
Today I discovered that the screw on the Fuel Damper on the rail was very loose. Is this supposed to be like this? I tightened it up and it seems to have stopped the car from dying, but now the car is running super rich. I'm guessing I'll need another tune as it was last tuned with the screw loose.
Let me know if you have any input on this fuel dampener. Any help is much appreciated.
Thanks,
Chris
Old 12-12-2012, 07:57 PM
hybrdthry911's Avatar
Thanks,
Chris
Which screw did you turn pictures Would help for this. Chances are you changed the base pressure and will need to readjust back to the original base pressure. I doubt u even know What your base pressure was before though. Do you have a gauge to show fuel pressure?
Old 12-12-2012, 10:17 PM
chris2k03's Avatar
Old 12-13-2012, 07:10 AM
Was expecting the adjustable regulator but thats the stock one. Not sure what effect would be of that screw loose. What is your base pressure at now?
Old 12-13-2012, 07:48 AM
soulicious's Avatar
The dampener doesn't regulate fuel pressure. It's on the feed side.
staylor725
06-25-2017 04:17 AM
chubbys2k
06-27-2016 07:01 PM
Habitforming
11-26-2015 05:48 AM
CyS2k
08-22-2014 11:21 AM
2QYK4U
06-24-2007 11:22 AM
Quick Reply: Fuel Damper Screw Loose
