fuel pump noise, normal?
Old Dec 23, 2007 | 11:20 AM
fflatulip's Avatar
Default fuel pump noise, normal?
i have the whole vortech sc setup including the fuel pump, i ve noticed recently when the gas get lower approching empty, the fuel pump sounds crazy, especially when the car is idling. after i fill up gas, the sound gone
is that normal? or is this suggesting i need a new fuel pump.
Old Dec 23, 2007 | 02:56 PM
05TurboS2k's Avatar
did u not read the post 2 below this? you have the 255?
tottally normal
Old Dec 23, 2007 | 03:14 PM
AirborneS2K's Avatar
This s2k crowd seems much too whiney about the smallest *side effects* to their power mods....
Old Dec 23, 2007 | 08:32 PM
stantaur's Avatar
I don't mind a little noise, but my concern was whether the increase in noise foreshadowed pump failure.
Old Dec 23, 2007 | 09:21 PM
flexmyrex's Avatar
The high flow pumps tend to be noisy which is normal, I try not to run my cars on low. A pump is a simple DC motor that is constantly on and generates heat, it has no way of cooling itself. The fuel is the only source that it has to dissipate the heat. The high flow pumps require more amperage which again contributes to generating more heat compared to a stock unit. As your fuel level gets lower the pump has to work harder to keep the line pressure at a desirable level, the higher fuel level in the tank will keep the pump at cooler temperatures and can also help dampen the noise.
Old Dec 23, 2007 | 09:32 PM
05TurboS2k's Avatar
...whiney or concerned?
Fuel pump is one of those things I recommend being whiney about rather then calling your friend for a tow later that evening on the way home from your drive.... Don't you think?
OH AND THE POST ABOVE IS RIGHT ON THE MONEY...ive found exactly those points to be true on my 255.
Old Dec 23, 2007 | 10:25 PM
Elite Performance's Avatar
now imagine the sound of an 1000 series external magnafuel pump ! i hear it everyday doesnt bother me one bit LOL
JayJones
Apr 13, 2014 04:29 AM
Tom.D
Apr 4, 2011 10:22 PM
PUNCHIN-IT
Apr 9, 2010 07:22 AM
nightcrawler7188
Nov 15, 2008 03:47 PM
jwkim
Apr 17, 2005 08:11 PM
