Gears + Boost
Old Jul 15, 2009 | 10:12 AM
  #21
Soul Coughing's Avatar
i run a 3.90 rear end and enjoy shifting less. Its not too much of a difference on the lower gears, but on the higher gears i get 5-8 more mph per gear. Lots of things are different but I have kept up or beaten friends making more horsepower as i stay in a lower gear longer. Its all anecdotal, but still has some merit.
Old Jul 15, 2009 | 10:45 AM
  #22
boostedf22c's Avatar
You guys also have to remember the stock reduction gears when factoring rear end final drive ratios.
AP1 reduction gear is 1.16:1
AP2 reduction gear is 1.20:1
So whatever your rear end ratio is, times by the above number for the model you have.
For example
A 3.9 rear end in a AP1 is effectively a 4.524
A 3.9 rear end in a AP2 is effectively a 4.68
Old Jul 15, 2009 | 11:06 AM
  #23
petawabit's Avatar
Originally Posted by siadam,Jul 15 2009, 07:24 AM
Is it just me then complaining about the stock gears?
I've debated about doing this so thing, so no:P I sold my 4.44 gears when I decided to go turbo and was always wondering if I should be shifting too much with the stock tranny and FD.
Old Jul 15, 2009 | 11:27 AM
  #24
siadam's Avatar
Originally Posted by boostedf22c,Jul 15 2009, 07:29 AM
You could always get the PPG drop gear, which will effectively lower your rear end gearing tremendously. I used to shift all the time, with this setup, I can almost go through the traps in 3rd gear, and I'm in the mid/high 130's
http://www.ppgearbox.com.au/page.asp?paren...35&productid=78
Aren't most ppg gearsets $$$ ?
I don't see a price.
Old Jul 15, 2009 | 11:42 AM
  #25
ComposiMo's Avatar
Convert to a slushbox? Its a manual transmission... the ratios are close for a reason... its just part of the ride.
and changing gear ratios so that you can "stay in gear longer" only minimises the torque multiplier at your wheels, so technically, you'd be accelerating slower... but i guess you'd "be in gear longer" so maybe you'll feel faster? dunno...
I'd leave it the way it is, and learn to shift faster than your friends, so that you don't lose as much per shift
Old Jul 15, 2009 | 11:46 AM
  #26
Depends on your power too. At 500whp+, the stock gearing is far from optimal.
titus69
Aug 3, 2015 04:33 PM
OHclassic
Oct 1, 2012 07:33 AM
emac0408
Dec 11, 2009 09:49 PM
afwfjustin
May 21, 2006 05:31 PM
S2K00
Jan 19, 2006 12:28 AM
