Greddy Turbo Install
Old Jan 21, 2008 | 10:43 PM
  #31
Mystiqueskillz's Avatar
Damn you finally finished the install! Congrats and have fun and tell us what you think!
Old Jan 21, 2008 | 10:45 PM
  #32
bigwhite's Avatar
After you finalize this write-up, you are supposed to start the following write-ups:
-Greddy Boost Controller Install
then;
-Greddy Turbo 12psi tuning
then;
-Safe 300whp on Greddy kit, ever increasing torque line
Old Jan 21, 2008 | 11:37 PM
  #33
LegendaryHarry's Avatar
then:
dismantling my turbo kit and then re installation of turbo kit of LegendaryHarry's car.
Old Jan 22, 2008 | 05:49 AM
  #34
S2Kart's Avatar
The cast manifold looks like it is the same shape/size as the tubular SS.
Still no cracks . . .
Old Jan 22, 2008 | 08:00 AM
  #35
Chris_Lum's Avatar
good write up, but you don't need to put teflon tape on the turbo side oil union when connecting the feed hose b/c if u look in the hose and in the oil union you'll see that they have a taper that matches each other. This taper is what seals the union to the hose. pretty sure it's like this on the L shaped fitting coming off of the T fitting.
Old Jan 22, 2008 | 08:11 AM
  #36
Jaxice's Avatar
great write up, good thing you wrote up the B**** moments so that we are aware int he future now all we need is an 06-07 with dbw to do the write up
Old Jan 22, 2008 | 08:12 AM
  #37
kix's Avatar
kix
then;
then;
umm... ok
Next on the list is
-Greddy Type RS BOV which I should have in this week
-Boost guage
-AF guage
-Berk high flow cat
-ReTune/Dyno @10 psi at Church in Long Beach... hoping for 325whp
I do have a question tho. Can the tuners get 10psi out of the turbo without a boost controller?
Old Jan 22, 2008 | 08:14 AM
  #38
Chris_Lum's Avatar
The only other way would be to adjust the actuator rod, but not even sure if 10psi can be reached. Otherwise, there is no way to raise boost consistently w/o a boost controller.
Old Jan 22, 2008 | 08:21 AM
  #39
8kGoodENuff's Avatar
Question... in the vid, there seems to be a lot of smoke coming from the turbo section. What was or is that?
Andre
Old Jan 22, 2008 | 08:22 AM
  #40
Beautiful Job by the way.
You did a F**KING AMAZING JOB!!!!
Thanks man,
Andre
