Greddy Turbo Install
Originally Posted by Chris_Lum,Jan 22 2008, 11:24 AM
You are correct, all of the greddy cast manifolds do this upon startup, i'll only last a day or two.
Also, what do I need to do to get a base map from greddy? I already had an emanage ultimate in the car and don't need the one in the kit (will be for sale soon). Will they give me one without any hassle?
Also, I have test pipe and a nice single exhaust on there, any potential issues with running the base map for a month or so until I can get it properly tuned? I do have the boost controller and BOV with the kit and intended to limit boost to the stock level until I could get it tuned.
To the OP, awesome job, thanks for the excellent post. I can't wait to get mine done and feel what you are feeling
J
Originally Posted by LeonGalt,Jan 22 2008, 07:44 PM
I just happen to be doing my greddy install as we speak as well. I had my cast manifold ceramic coated, hopefully to keep some heat in. Thoughts? Good move, bad move, waste of time?
J
J
call greddy and they can email you an unlocked basemap.
I'm not sure about the A/F with a testpipe, but i know the boost will spike like a madman w/ a testipipe on. Might as well just have your stock cat on there for that month until you get it tuned....the cat is easy enough to swap out for the testpipe once you are ready to tune.
^ you can always put a blocking plate on the flange when you go in for smog
But seriously tho, what is their problem about releasing the same air the charge pipe took in?
Originally Posted by kix,Jan 20 2008, 02:42 AM
Other than that, the only annoying sounds are the intake AND the compressor surge.
In comparison to your sex reference... it's like having sex with a girl that moans and screams... just makes it that much better.
Andre
Andre
Andre
