Greddy Turbo Kit !DYNO!
Here is my GReddy kit installation experience which was done a few weeks ago;
I'm running the pre-tuned map from emanage. With the software I'm able to see where it is tuned conservatively. Fuel delivery reduction start @ 5500 rpm and going down from there (see chart).. I have started to increase the fuel delivery values in those area with hope that the HP will increase with it, but I haven't upload the new map into the emange and give it a run yet.
I have a thread about the installation and progress here;
http://forums.s2kca.com/showthread.php?t=18084
Originally Posted by MugenRioS2k,Oct 29 2007, 07:43 AM
TPS based Injector duty cycle
Not the way I would have done it.
Zero value = stock cycles.
Remember there is already a scaling factor added in to the injector values in the vehicle tab where you select the factory injector size and the curretn size.
This effectively scales back the larger injectors duty to give the same fuel as the stock injectors supplied.
Hence the reason it has 0% in those cells.
Originally Posted by deathsled,Oct 29 2007, 11:54 AM
damn, doesnt the Greddy kit come with the pressure sensor for the EMU? I'm pretty disappointed to see they're not tuning off MAP
