Greddy Turbo Questions thread....
[QUOTE=KnowledgeIsPower,Apr 14 2008, 03:22 PM] my kit is installed and running good. im running aem tru boost. ive hit 9lbs of boost on partial throttle only up to 5krpms. i have oem cat and 80mm catback on currently.
Originally Posted by devs2k,Apr 14 2008, 11:42 AM
with 80mm exhaust and test pipe i can guarantee you'll be very high
IMHO I wouldn't run the 80mm TP with the 80mm single. You'll probably spike higher than mine and the tuner might have to make it run rich like mine did which isn't fun.
Hey Aqua, im going in for tuning tomorrow morning. What should I look out for, and what should I do to prepare.
I have a 63mm Test pipe. I'm thinking about putting it on, so i'll have Turbo > Greddy 60mm Down pipe > 60mm Invidia Test Pipe > 63mm Stock Exhaust
I have the truBoost as well and I want to run 10psi as well.
what PSI are you hitting with the stock exhaust? I would put your TP in and see what kind of boost you hit in the higher RPM range. My boost didn't start creeping till about 7k on up. So you'll have to rev it pretty high to make sure your not going to creep past your 10 psi goal. Just in case bring your cat with you to your tunning session.
Originally Posted by Mr.Aqua,Apr 14 2008, 01:20 PM
I boost creeped till 12 psi around redline and hit 300 HP on a dyna pack.
Originally Posted by NFRs2000NYC,Apr 14 2008, 10:04 AM
From what I've been told, at 12psi this turbo is inefficient,
After 14 psi the power just fell on its face.Started of good under early boost but then dropped of very quickly. Was making far better numbers and driveabilty without the HG. Didnt even bother getting a dyno sheet because was kinda pissed at the situation but Mase will vouch for the outcome. He's back in the UK in a couple of weeks so since he last left have taken the 3mm HG out and we sent the turbo for inspection to make sure it was okay because had been beating some higher psi numbers on it for a while. Company here said they could fit 20G internals in it so thats what we did.
Its all being put back together now awaiting mapping. Will post the dyno up. May seem like a lot of work to you guys but here in the UK we are very limited for manifolds and turbo size due to our steering rack position. Just trying to make the best of what i got
Originally Posted by mcmap1,Apr 13 2008, 08:15 PM
is anybody planning on running the Greddy e-01?
In 1st gear if I get on it very hard it spikes slightly over 10PSI, for just a second, but buy the time I am above, 6000RPMS it falls down to like 9, this is not dangerous is it, that is spikes slightly above 10PSI for a second or two? At redline it is at a steady 9ish
