Greddy Turbo Questions thread....
Old Jul 11, 2008 | 09:09 AM
  #991
TRBOKEV's Avatar
anyone?
Old Jul 11, 2008 | 09:15 AM
  #992
SgtB's Avatar
Pull the code. If it sees something suspect, some codes get stored and then the second one throws it. It may be the "too rich" code. I dip below 10's all the time, never thought anything of it, although it is stupid rich. Not sure about the led. Usually it should slowly rise and fall to show an rpm signal. The manual shows what each flash type means.
Old Jul 11, 2008 | 11:33 AM
  #993
TRBOKEV's Avatar
Read that the pulsing on the light is it verifying RPM.
Drove the car to lunch and was fine to the drive thru. Then on my way back any time I went into boost the car just bogged and the AFR's went to ten (most rich display on the AEM wideband) and it just dumps on its face..
Something is definitely wrong and I need to figure it out ASAP.
Old Jul 11, 2008 | 03:27 PM
  #994
brilliant's Avatar
gotta get tuned man!
Old Jul 11, 2008 | 03:56 PM
  #995
TRBOKEV's Avatar
Its not the tuning, the base map ran fine before....
Something is wrong electronically with the car IMO. Did a map whack, and checked the plug and reset the ECU at lunch so lets see how she drives on the way home today.
Old Jul 11, 2008 | 04:47 PM
  #996
SgtB's Avatar
Is it hotter than usual there? It's stupid hot here, and my car is running extra crappy.
Old Jul 11, 2008 | 06:20 PM
  #997
TRBOKEV's Avatar
Once it did it due to weather change but this time that was not the cause. It was sixties on the way to work and then in the eighties during lunch so no it wasnt stupid hot. In the morning it was freaking in VTEC (super rich and bogged to death) then at lunch it was horrible and just dumped fuel into the motor for a "mega bog" at any boost it saw.
The car ran fine on the way home. All I did at lunch was reset the ECU, map whack and unplug/plug back in the map wire and re zip tied it. Also whacked that big cad plate gold sensor at the rear of the intake. LOL
This is starting to frustrate me though. Wonder if my map sensor is going out or something since the problems are only at first in VTEC an then it worsens to all boost conditions.
Old Jul 17, 2008 | 12:35 PM
  #998
S2005x's Avatar
Hey everyone! long time no see...
Mine is still running.... and I don't think anything is wrong with it, but I have no idea...
My temp gauges (OEM dashboard) still dosent work.
It still ocasionally gets mad at me spits hisses and pops (Engine), probably misfiring and backfiring... maybe a problem with my timing...
I think imma go get it re tuned and use soemone I trust... only problem, I live in South Alabama, and I have NO idea how to find a good tuner...
Also, what is a Map whack?
Old Jul 17, 2008 | 12:53 PM
  #999
WLAURENT's Avatar
Since the emanage adds x% fuel to what ever the ECM is adding you will find a fairly large difference with varied temperatures. My car goes open loop 13.1 AFR when it is 60F, but goes open loop 10.4 AFR when it is 110F.
If your tune was adding a percentage of fuel that pulled it from 13:1 to 11:1 when it was 60F out - you are looking at an 18% increase in fuel. If your ECM is trying to add 10.4:1 worth of fuel at 100-110F - you are still adding 18% more fuel from the eManage bringing it to well below the 9:1 AFR range.
The fix would be to use the IAT compensation map. I have played with my IAT Map to try to keep it in the 11.8range when cooler and in the 10.5 range when it is hotter out.
Old Jul 17, 2008 | 01:16 PM
  #1000
JoeyBalls's Avatar
Mine spikes to just over 10, early in the RPMS and settles to 9 Around redline, perfect for me
